Fuel Over flow
Old Jun 13, 2024 | 01:18 PM
disco96sd's Avatar
Default Fuel Over flow
Went to fuel yesterday and noticed that there was no pressure release when I removed the cap - fueled up and right at the fill point fuel started to poor out of the filler - pump didn't shut off - what would cause this ? faulty pump handle or issue with filler tube etc. ?
Thanks
Old Jun 14, 2024 | 10:01 AM
DHTaylor's Avatar
There is a hole in the tubing going down to the tank. This hole allows air to flow upward and into the nozzle of the gas pump. When air travels through this nozzle, pressure builds up which that keeps the nozzle open and engaged. If the airflow does not stop - as it is supposed to do, the gas keeps coming. To say it is clogged would mean that no air would flow. However, the nozzle would likely immediately shut off because there is no pressure flow building up.
That is the mechanics of the nozzle. Why yours does not shut off means something is askew - and I am betting you know that already.
Here's a simple video breakdown. If nothing more, you may be able to look at a few things knowing what is involved:
https://www.tiktok.com/t/ZTNJ6r4Qf/
Old Jun 14, 2024 | 09:40 PM
Harvlr's Avatar
Before tearing into it, I’d try refuelling at a different location and see if the same thing happens. (In case it’s the pump and not your truck)
Old Jun 16, 2024 | 09:45 AM
jimvw57's Avatar
could be a bad pump nozzle, I'd start there.. try a different pump or station before getting to worried about it.
attworth
Sep 27, 2020 08:39 PM
Shaky Disco
Nov 6, 2018 06:23 PM
rkbowles
Nov 9, 2014 04:43 PM
mick robinson
Jan 2, 2009 08:29 PM
ajordan_0012000
Oct 8, 2008 06:30 PM
