Fuel pressure?
Old Dec 3, 2013 | 07:24 PM
ESPN's Avatar
Default Fuel pressure?
What is the factory fuel pressure at idle? With the ignition on and the engine not running, I get about 35psi (normal). But when the engine is idling I am getting about 55psi. Is that too much pressure? I just replaced the fuel pressure regulator thinking that it was to blame, but have had no luck with a new one.
Old Dec 3, 2013 | 07:28 PM
ihscouts's Avatar
How much did you spend on the FPR?
Old Dec 3, 2013 | 08:39 PM
ESPN's Avatar
New OEM one. $180.
Old Dec 4, 2013 | 09:14 AM
ajnolin's Avatar
That seems awfully high. If I remember correctly the fuel pressure shouldn't be going over 38 or 39psi. Are you getting good vacuum to the FPR ?
Old Dec 4, 2013 | 12:13 PM
ESPN's Avatar
It has enough vacuum to suck my finger to the hose, but that is all i can tell you. I have no way to measure the vacuum.
atikovi
Mar 27, 2016 09:05 PM
JumPeR04
Apr 7, 2011 09:52 PM
leadfoot
Sep 13, 2009 09:51 AM
discoken
Nov 4, 2008 12:39 AM
discomech
Jun 25, 2006 03:12 AM
