Fuel pressure situation
Old Sep 3, 2012 | 02:30 PM
tweakrover's Avatar
Default Fuel pressure situation
Hey guys I've been dealing with an issue for a while and decided try to get it straitened out. A while back I attempted to change out the fuel pump, long story short I was gonna change just the pump and keep the assembly but the pump had different electrical connections and I wasn't gonna splice wires in my gas tank, so the old one went back in. Since then my truck won't start when warm til the third try cranking it. Here are the numbers 38 psi when pump primes, nothing after pump stops after prime, just over 30 while running. From what I know these numbers are good but it should hold pressure after the prime correct? I haven't found any external leaks so I'm thinking I damaged the hose between the actual pump and the fitting at the top of the fuel pump assembly. If this is the case what kind of hose should I use to replace it, I dont have cash for a whole new unit, and I dont see the point cause I seems it's producing enough pressure. Thanks guys.
Old Sep 3, 2012 | 02:40 PM
Agree that it should hold pressure, but that could be leaks elsewhere as well. If you do the switch on, count two mississippi, off, and repeat three times does that make enough PSI to crank? At one or two tries you should eb up to that 30 PSI range.
Also, hot restart is impacted by the fuel temp sensor, which changes the width of the pulse to the injectors (keeps them open longer) to get rid of bubbles in the fuel.
And then there is always the ignition amp module....
Old Sep 3, 2012 | 04:33 PM
tweakrover's Avatar
Yea if I prime it a few times it is more likely to start first try but not nessisarily, also when its cold it starts easier not always first try either. I'm suspect the line cause it started after puttingthe pump back in.
Old Sep 4, 2012 | 08:01 AM
When was the fuel filter last changed, what is the pressure after sitting over night before priming the pump?
You may also have plugged up injectors for the liner on the inside of the rail flaking off and plugging the screens.
Old Sep 4, 2012 | 12:23 PM
tweakrover's Avatar
The filter should be fine it is a couple years old but I had the tank replaced before it, but I'm getting pressure and it runs fine just doesn't hold pressure.
Psichotic
Sep 20, 2016 11:20 PM
tweakrover
Feb 17, 2010 12:11 PM
flattrakker
Jan 15, 2008 06:11 PM
RovingRiesensCubed
Jan 12, 2008 01:11 PM
DiscoDiva
Jan 29, 2007 08:00 PM
