Fuel Pump
Old 03-19-2012, 02:00 PM
carolinadisco's Avatar
3rd Gear
Default Fuel Pump
Lost power and towed to a shop. They are quoting around $1100 to replace the fuel pump. Checking online there are ones that are around $200 - new. Not wanting to name brands, is there any quality issues to be worried about? I just bought my 1998 and want to get started on the right foot...
Old 03-19-2012, 02:02 PM
jafir's Avatar
Go ahead, name brands. No one here cares, and you'll get better answers. Anyway, you'll be hard pressed to find a model year 1997.5 and up fuel pump for $200. Starting mid 97 they added advanced evap emissions and those pumps are all about $400 and up.
Old 03-19-2012, 02:12 PM
3rd Gear
Thanks...this one is from Auto Parts Warehouse, the claim is that it fits the 1994-1999 models. The ad doesn't claim that the pump has these advanced evap emissions, maybe this one isn't a good idea. I'll keep checking.
Old 03-19-2012, 02:49 PM
pinkytoe69's Avatar
Easy way to see the difference...
The AEL one will have two plug inputs for the electrical connectors and will cost around $400.
The pre-AEL will have one connector input and can be found from $50-200.
Old 03-19-2012, 02:59 PM
3rd Gear
Thanks!!!
Old 03-19-2012, 03:08 PM
Look at the Rover's North Website. They have the best prices on new fuel pump assemblies that I was able to find. My early 97 is the Pre-AEL version and was 100 bucks new for their ProLine.
Also make sure the problem is not merely the fuel pump cut off switch under the hood on the firewall. Reset that switch by pushing down the top of it and see if that matters. Also go ahead and pull the fuel pump cover in the rear cargo floor and visually examine the pump. Check for power at the connector with a meter.
Mine had extreme corrosion present that required complete replacement of fuel lines from pump to engine compartment and fuel pump assembly replacement due to cracks in the plastic top plate.
For $1100 I would drive down there and replace it for you.
Also if the top and such are in good shape, you may get by with just replacing the pump itself. You will save a lot of money doing these basic repairs yourself. The price they quoted you is like robbery in my opinion. Replacing the fuel pump assembly is very very simple..
Old 03-19-2012, 03:31 PM
EricTyrrell's Avatar
If you live in an area without emissions/inspections then you could probably remove the AEL system and use the cheaper pre-AEL pump. I've already removed most of the AEL system and that's what I'm going to try to do when my pump goes.
Old 03-19-2012, 03:38 PM
pinkytoe69's Avatar
Yeah, this too.
If the $1100 is just to do the fuel pump, you are getting ripped off epically.
Procedure is almost literally:
1. pull up carpet in cargo area and remove cover to pump
2. unscrew retaining ring, unplug electrical connections and pull old pump out.
3. put old pump in, re-connect all wires, screw on retaining ring
4. cover everything that was uncovered in step 1
the only humbug is cleaning up spilled gasoline.
Old 03-19-2012, 04:12 PM
Rover repairs are frequently based on MSRP of current vehicles... just like other posh pre-owned piles of prime sheetmetal, including BMW, Mercedes, etc. There is no discount for working on old ones at the dealer.
Old 03-19-2012, 04:15 PM
pinkytoe69's Avatar
Even so, that price seems like they are billing him at about $500/hr
Quick Reply: Fuel Pump
