Fuel pump Evap or no?
Ok. I put that Warner pump in and it died twice. I guess the warner might not have been rated correctly. Could I run the non evap and just unplug the evap? I live in VA so I'm not worried about smog etc... what would it do? Would it run? How hard it it to just replace the pump vs the whole unit? Thanks guys!
It is very easy task 20mins if you work slowly. Buy a new filter (both inside and outside the tank) and fuel injection hose. Once out of the truck the pump is removed quickly from the housing/ cut the 5/16 fuel injection hose to size. The electrical is the same plugs right in. Works well saves money and you will keep it stock.
Travelor
09-24-2015 06:11 PM
pwaltrip
11-20-2012 07:12 PM
JumPeR04
04-07-2011 09:52 PM
