fuel pump looses power...
Old Feb 16, 2011 | 12:07 PM
  #21
Danny Lee 97 Disco's Avatar
The pump could be on it's last leg. After all it is at least 16 years old. I put a new ProLine in my early 97. RN has them for right at 100 bucks for the pre-AEL like your 96 uses. Mine is doing great.
Old Feb 16, 2011 | 01:36 PM
  #22
Chris-bob's Avatar
Crankshaft position sensor (CKP Sensor)
The crankshaft position sensor is the most important
sensor on the engine. It is located in the left hand side
of the flywheel housing and uses a different thickness
of spacer for manual and automatic gearboxes. The
signal it produces informs the ECM:
- the engine is turning
- how fast the engine is turning
- which stage the engine is at in the cycle.
As there is no default strategy, failure of the
crankshaft sensor will result in the engine failing to
start. The fault is indicated by illumination of the
malfunction indicator light (MIL) on North American
specification vehicles.
Old Feb 16, 2011 | 01:39 PM
  #23
Chris-bob's Avatar
Not saying that is the problem. But if the pump works, and the relay works, then it points to the ECM that energizes the relay that powers the pump, or the Crank sensor that tells the ECM the engine is running. Can't hurt to check the CKP Sensor before condeming the pump.
Old Feb 16, 2011 | 04:18 PM
  #24
Rearden Steel's Avatar
Does your Disco start at all? And then die because the fuel pump turns off? Or does she not fire over at all?
Old Feb 16, 2011 | 09:40 PM
  #25
dansgt's Avatar
no cel so i don't think its the crank sensor. i'll have to feed power to the pump and see if it goes, i haven't checked that cuz i wasn't seeing normal power.
it doesn't start at the moment, it was just cutting out intermittantly and then it died all together and would just idle, now it won't even fire up. i had it start once when i was checking stuff but it died 10 seconds later.
honestly the more l look into stuff it seams that may be my issue. 100 for a fuel pump isn't bad at all so if thats it its a cheap fix.
Travelor
Sep 24, 2015 06:11 PM
coldstart
Mar 9, 2014 07:08 PM
Sandman0306
Dec 15, 2012 03:24 PM
JumPeR04
Apr 7, 2011 09:52 PM
Michael K
Oct 3, 2008 07:42 PM
