No start, power to coil, no spark, no power to fuel pump
Old Dec 15, 2012 | 12:08 PM
Sandman0306's Avatar
Default No start, power to coil, no spark, no power to fuel pump
I am having start issues, the engine turns but won't crank. We just replaced the crank sensor and new fuel pump. Their is no spark or power to fuel pump. Their is power to the coil. We can bypass the relay to get the pump to run, we have swapped relays to check for bad. Inertia switch has been reset also.
Any & all help is appreciated! Thank you In advance.
Old Dec 15, 2012 | 12:12 PM
lr2001silver's Avatar
Banned
Do you have any codes?
Inertia switch has been reset? Was it tripped?
Does it start when you bypass relay?
Did you install the spacers properly on crankshaft position sensor?
Old Dec 15, 2012 | 12:21 PM
Are you sure you replace the sensor as it came off with the sensor to the block, then the spacers and nuts?
Old Dec 15, 2012 | 02:29 PM
Thanks for the replys, I feel like an idiot now, I completely over looked where the spacers were, had them in the wrong spots. Thank y'all for the help.
Old Dec 15, 2012 | 02:52 PM
Banned
Its no problem we are here to remind you of simple things like that!
Old Dec 15, 2012 | 03:18 PM
Not a problem. Get us something harder for your next thread.
Old Dec 15, 2012 | 03:24 PM
Haha hopefully nothing major will come up, but I am glad to know you are up for a challenger just in case I come across 1.
Travelor
Sep 24, 2015 06:11 PM
coldstart
Mar 9, 2014 07:08 PM
johndavidrichards
Jun 17, 2011 09:26 PM
JumPeR04
Apr 7, 2011 09:52 PM
