Fuel Pump May Have Just Gone
Old 03-06-2011 | 06:32 PM
groundandpound's Avatar
I would check voltage at the pump. The ground is above the tank, to the frame or cross-member.
If power at the pump is positive then I would
I would pull the pump and connect direct power to it. If you see/hear the "dragging" then you know it is the pump.
Chris II
Old 03-06-2011 | 06:33 PM
dansgt's Avatar
did you try smacking the pump? mine did the exact same thing a few weeks ago, was the pump.
Old 03-06-2011 | 06:36 PM
I found out my kid was a problem using the same method!
ROTFL - USMC Troubleshooting - if it don't work, get a bigger hammer and smack harder.
Trust me, typically fixes it for me!
Old 03-06-2011 | 07:03 PM
LeakyDisco's Avatar
Yes, if I tap on the top of the pump, the engine runs normally. A minute or so later it starts to sputter until I tap on the pump again. Pretty sure it's the pump.
Old 03-06-2011 | 08:14 PM
Originally Posted by LeakyDisco
Autozone wants more than $500.
How about this one?:
http://www.roverparts.com/Parts/WFX101020K.cfm
The proline is $399 from Rovers North.
Having AEL makes it more expensive.
Get the on from AB.
Mine from AutoZone was ~$400 because I had rewards points and they matched Advance Auto's price.
I needed the truck back up and running straight away so I was willing to pay more and not pay shipping or wait for shipping.
Old 03-14-2011 | 03:18 PM
LeakyDisco's Avatar
Default Fixed!
Replaced the fuel pump today with the one from AB. Took about 1/2 hour start-to-finish.
She purrs again!
I also replaced the PCV stuff (coulpe hoses and oil cleaner thingy), and the cruise control lines. However, when replacing the line to the foot switch, I broke the plastic tabs that hold it to the brake pedal.
D'oh!!
stanigu
04-13-2010 09:35 AM
ljdiscovery
10-29-2009 09:47 PM
Disbet
10-13-2009 03:38 PM
Quick Reply: Fuel Pump May Have Just Gone
