Shifter loose - Just realised i may have asked the wrong question before
Old Apr 30, 2010 | 04:46 PM
elboy0712's Avatar
Default Shifter loose - Just realised i may have asked the wrong question before
Before I asked if i had to remove the whoel console to get at the shifter bolt. Got an answer that may be for a differant question.
the shift lever itself is not loose, it is loose when shifting between gears (exception of park) I have to kind of go back and forth till it seats in... how can i tighten this. Everyone before said there is a bolt underneath it. but when i remove the trim piece around the edge there is the otehr black piece(which has the P-R-N-D-3-2-1) on it. this doesnt seem to just POP off. It is really starting to annoy me and i would love to tighten it back up.
Can I maybe get an idiots guidence on this one..... Cause I sure feel like one.
Old May 2, 2010 | 10:49 AM
elboy0712's Avatar
I hope you all realize iby idiots guidence I meant guidence an idiot can follow that's me..
Old May 2, 2010 | 12:10 PM
03discoman's Avatar
remove the shifter **** (pull up real hard), remove the shifter cover(prnd321) unplug the harness for the lights
you probly need a new shifter handle , the spring inside might be weak... the shifter assembly is a aluminum track that the shifter follows inside, i bet you just need the shifter handle
http://cgi.ebay.com/ebaymotors/LAND-...item25598e1a31
this is way too much.. i can get this for 25$ all day
Old May 2, 2010 | 12:29 PM
greg409's Avatar
It's a DI, in the rave manual, in electrical - repair - shift indicater lite, or something like that, it describes how to easily remove the parts you refer to.
below in my sig is a download to the rave manual.
luck,greg
Old May 10, 2010 | 08:22 PM
elboy0712's Avatar
can i adjust this at the selector arm on the transmission bell end of the cable? or is my issue most likely related to the mysterious bolt i have been seeking for so long
FLA Rover
Jun 14, 2015 11:52 AM
taylorm334
Apr 24, 2013 07:27 AM
LeakyDisco
Mar 14, 2011 03:18 PM
robot808
Nov 18, 2009 11:10 PM
Mountain_Ox
May 9, 2009 08:37 PM
