fuel pump pressure for a 95 disco?
Old Jun 25, 2011 | 12:55 AM
collin Barrows's Avatar
Default fuel pump pressure for a 95 disco?
I'm having trouble with my disco stalling out after driving 50mph... i think it may have to do with the fuel pump... any other ideas?:con fused:
Old Jun 25, 2011 | 07:08 AM
Is it stalling out once you hit 50?
Or after you slow down and stop?
Fuel PSI at idle should be in the low 30's.
Old Jun 25, 2011 | 12:36 PM
It stalls out after I slow down, I just replaced the fuel filter, vacuum hose, cleaned the mass air sensor, used some drygas, gave her premium gas, replaced the coil, replaced the gas cap (it was broken to begin with), changed out 1 of 2 temp senors and still have the same problem... My fuel pump is running at 38-35lb at idle
Old Jun 25, 2011 | 06:10 PM
Sounds like a bad or dirty idle air control valve.
Old Jun 25, 2011 | 07:15 PM
will check that out... Thanks You
Travelor
Sep 24, 2015 06:11 PM
Timebus
May 4, 2011 07:34 PM
JumPeR04
Apr 7, 2011 09:52 PM
leadfoot
Sep 13, 2009 09:51 AM
discoken
Nov 4, 2008 12:39 AM
