Fuel Pump shortage?
Old Apr 18, 2016 | 02:38 PM
Toran's Avatar
Nice jafir!
Thanks for the part number, this could turn out to be a cheap fix for once!
LOL
Is the other end of this harness inside or outside/underneath truck?
Thanks
Old Apr 23, 2016 | 03:22 PM
Toran's Avatar
The new fuel pump harness arrived. How does one install it?
I looked under the truck and saw no signs of this harness. From within the cargo area how do you get access to remove the old and replace the new?
However it looks I have to remember to give myself three times the amount of time to complete!
T.I.A.
Old Apr 24, 2016 | 12:31 AM
number9's Avatar
ETM indicates C407. LH rear WW. IFW, I follow wires.
If you have a meter might want to check resistance to ground if that socket goes to a black/gnd wire. A lousy gnd would eventually burn your new harness.
File Type: pdf
Old Apr 24, 2016 | 07:13 AM
Toran's Avatar
Thanks number9 for the file and the advice.
I need to put my thinking cap on and get back out there in that area!
Will a common size hand be able to pull the new harness through to the connect to the pump or will I need a wire or something to snake it through?
Thanks
Old Apr 24, 2016 | 07:23 AM
fishEH's Avatar
The harness commector is in the drivers rear wheel well, between the body and frame. Disconnect the old one and tape the new one to it. Then go back to the fuel pump and pull the old one out/new one in. Untape and connect.
Old Apr 24, 2016 | 07:27 AM
Toran's Avatar
My god Fish, look at your genius shining through!
You put a smile on my face and made me shake my head at the same time!
This forum rocks!
Thank you!
Old May 3, 2016 | 09:43 AM
Toran's Avatar
**Update**
My 96 required the other harness, part #AMR2587G.
Sure enough if you look within the drivers rear wheel well you can spot the connector end for future reference.
Thanks again Everyone for the help!
Travelor
Sep 24, 2015 06:11 PM
coldstart
Mar 9, 2014 07:08 PM
JumPeR04
Apr 7, 2011 09:52 PM
ljdiscovery
Oct 29, 2009 09:47 PM
XBlade
Sep 24, 2008 04:12 PM
