Fuel Pump - Water Short??
New to the threads so please excuse me if I post improperly. About a year ago I took my '98 Disco I to the Dealership because it seemed to misfire at about 1500 RPM. If I let it engine idle for about 15-20 minutes, it would run fine. They replaced the fuel pump and it has run fine for the past year.
Now it's starting to do it again. It seems to act worse when it rains, so I took it through the car wash and sure enough, it started acting up again while in the wash. Brought her home, pulled the carpet up and noticed that there was water all around the area where the fuel pump was (probably from the under-carriage wash). Dried it out with a blow-dryer, cranked it up and everything was fine again.
Has anyone else had this problem? Is there a way to easily seal the area between the fuel tank and the body to keep water from shorting out the electrical connections?
Discovery I / 1998 / 147,000
Yes, I've got a multi-meter. Mike, I did have some fault codes last year, said it was some sort of valve. I'll run it again to see if it gives me the same codes and respond.
I should have probably said that the area that I dried out specifically was the electrical connectors on top of the fuel pump. I've got some silicon that I'm going to put on the top of the connectors to see if that helps.
I'll look in the rear driver's side well also for the multi-plugs. The reason that I took it through the car-wash was due to a huge nest of black widow spiders making a home underneath the rover. Not crazy about the idea of getting under there, but will do what needs to be done.
Thanks to everyone for your help. I'll run the diagnostic and see what pops up.
Savannah Buzz, I like your logo. Huge GT football fan since the 80's. I also live in Savannah, GA.
Oddly enough, it seems as though putting the liquid nails black silicone on the back of the electrical connectors is working (for now). It rained pretty hard tonight and I took the Rover on my regular commute to work. Where it usually starts cutting out, everything went fine.
I'll still hook it up to ECU monitor up to see what codes it pushes and advise at some point, but all seems well (for now).
Thanks everyone.
Thanks everyone.
