Gear issue?
Old May 11, 2021 | 02:59 PM
Snacs's Avatar
Default Gear issue?
Hey all and thank you,
I own a 1998 300 tdi automatic
I had the transmission sent to shop for total treatment after some. Issues.
Came back and drove fine for 3 days then something happened, as I was hitting the gas uphill the gas pedal went a little. Loose and something happened to the gears. It stalls shifting gears now and you really have to floor it so it can reach 3 and 4 gear. Any idea what the problem might be? ( tachometer also went loose and crazy at the same time) thank you!
Old May 11, 2021 | 08:49 PM
JohnZo's Avatar
On my 96 gas engine there is a cable that connects from the throttle to the transmission for kick-down. It's position needs to be adjusted carefully. Does the tdi have that cable?
kb24
Mar 8, 2016 08:31 PM
Arizona man
May 1, 2011 01:42 PM
yeager6
Sep 21, 2010 05:45 AM
EdwardRS
Mar 18, 2010 07:36 AM
exquizit23
Jun 5, 2008 02:56 PM
