Gear Slippage...
Old Mar 8, 2016 | 02:55 PM
kb24's Avatar
Default Gear Slippage...
Hi guys,
So lately my 2005 Land Rover LR3 has been slipping out of the drive gear.
It seems to only have slippage when I make a stop and it seems to not go in any gear it just shows blank so I have to hit it back to drive.
This is obviously dangerous because if I need to make a quick move in traffic and I dont notice the slippage, ill just sit there and rev untgil I put it back in gear.
So by habit every time im at a stop I check the dash to see if its still in gear just in case, or before I make a move in traffic I double check that its in gear first.
What could be the problem, do I need to replace anything.
Also, how much am I looking at to fix this??
Thanks guys!
Old Mar 8, 2016 | 03:21 PM
houm_wa's Avatar
@bbyer, could this be the RF Capacitor gone Tango Uniform?
Old Mar 8, 2016 | 07:10 PM
thorgal's Avatar
Slipping out of gear usually means tranny gear linkage needs work. Check Disco3.co.uk , go to their WIKI .there is a write up on that .
Old Mar 8, 2016 | 07:50 PM
kb24's Avatar
Hi, thanks for the reply, i went to the site but whats WIKI?
I found this, is this what you were referring to?
http://www.disco3.co.uk/forum/topic31656.html
If it is, I am not a mechanic so I would need to take my truck in for this.
ball park, how much am i looking at?
thanks again
Old Mar 8, 2016 | 08:24 PM
thorgal's Avatar
Yep..that's the one.
I have no idea how much though.It sure will be cheaper than diagnosing transmission alone.I would start with this as it is a relatively simple job and most likely your case.Did not have to replace the part yet as I lubricate gear level every year to avoid rusting therefore causing problems down the road .good luck
Old Mar 8, 2016 | 08:31 PM
kb24's Avatar
awesome thanks, ill run this by my mechanic.
bcolins
Jun 10, 2011 11:36 PM
Lee1140
Dec 1, 2009 10:17 AM
jim_darci
Feb 18, 2007 12:11 AM
SoCal Blue
Apr 7, 2005 08:59 PM
