Gearbox failure?
Gearbox failure?
I'm new to the forum but need a little help. I purchased a 95 Disco with a blown head gasket. I ended up replacing the engine due to the block being cracked. However after replacing the engine the truck didn't want to move. I decided to replace the tranny and it still doesn't want to go in gear. When I first started it it went into gear and pulled but when I took it out of low range it doesn't pull. So I put it back into low and it doesn't pull anymore. So I removed the console and decided to remove the solenoid and nothing. I'm at a loss and any insight would be appreciated. The truck moved just fine before replacement of any components.
jafir, I thought about that but I'm certain it seated. Would it have moved like it was supposed to? I tried the tranny before I completed bolted everything tight...i.e. only put 4 bolts in the tranny, no front prop shaft, only the rear driveshaft and no parking brakes installed. It was in low and it pulled like normal but like I said, when I put it in high is when it started. I've tried to go back into low but nothing happens. Looking down at the front of the gearbox I can see it wanting to turn when its in gear. I let it roll down the drive as it is on a slight incline and it took me 15 mins to go about 15 ft.
cosmickites
Defender
09-07-2019 04:51 AM
tchaudhry10
06-03-2015 06:10 AM
