Gears
Old Dec 30, 2013 | 09:38 AM
FantomRover's Avatar
Default Gears
Gotta upgrade my gearing, I've got 33s on stock gearing and its tolerable but not all that great on the highway. I know theres a lot of choices for gear and all that but what would be the best ratio? Ive planned on 4:11s since i got the 33s but i just went on lucky 8s site and saw the 3:75s. would that be a better combo or should i just go 4:11s?
Old Dec 30, 2013 | 10:35 AM
fishEH's Avatar
You should use this calculator to run the numbers.
http://www.ashcroft-transmissions.co...atio_calc.html
I think you'll be disappointed with 3.75 gears. Whatever you get make sure the front is reverse cut.
Old Dec 30, 2013 | 11:10 AM
dusty1's Avatar
cool calculator....fantom, did you come up with 4:11 on it?
Old Dec 30, 2013 | 12:10 PM
fishEH's Avatar
The calculator will get you pretty close. Tires rarely actually measure what they're supposed to so it will be off a tad. I'm running 4.12 Ashcroft gears on 315/75/16 BFG KM2's and it's almost identical to stock RPM's.
Old Dec 30, 2013 | 02:57 PM
dusty1's Avatar
I too was shopping gears...thought I needed 4:11. just got off the phone with gbr..........4.43 is what I ended up with...convincing conversation and helpful and looong worth the educated opinion
Old Dec 30, 2013 | 03:05 PM
fishEH's Avatar
Interesting. What kind of RPM's will you be turning on the highway?
Old Dec 30, 2013 | 05:56 PM
EricTyrrell's Avatar
3.9 should get you close to stock
Old Dec 30, 2013 | 07:45 PM
dusty1's Avatar
I shall find out, but was assured that it would not be crazy, if noticeable compared to 4:11.
all the extra ghetto fab bs, dual winch weight and 34s was the deciding factor.........
I too am interested to find out. my luck 10,000 rpms at 60mph
Old Dec 30, 2013 | 08:21 PM
CUpgt's Avatar
4.12 is a solid set up on 33s and 35s. My truck on 33s with Ashcroft 4.12s has plenty of pep for a Rover and does pretty good at highway speeds.
Old Dec 31, 2013 | 07:20 PM
I haven't had a chance to be near a computer in a few days but I plan to borrow the girlfriends tonight. When you say 4:11s would give you a good amount of pep for a rover, wouldn't 4:43s be a little too much pep?
