General Maintenance?
Old Jul 10, 2010 | 04:31 PM
  #21
turf63's Avatar
Awesome pics. Super helpful regarding the cdl issue. So you don't think trying to bully it first is the right avenue of pursuit? In the scheme of things with my truck that's probably a "next spring season" issue. Right now my focus lies in the 60k service and then repairing my head liner. I'm going to custom upholster it with digital desert camo fabric. Then if time allows this season I'm going to focus on the stereo. See my post in the av section if you have any insight into that matter.
Im not doing any off roading with the truck just yet so the cdl is gonna get back burnered but I'll definitely consult you when it's time
Old Jul 10, 2010 | 09:22 PM
  #22
Originally Posted by Danny Lee 97 Disco
Spike, thanks for the Pics. That will help tremendously. So what do we need to do as far as maintainng the axle breathers?
Just make sure they are not clogged.
Remove them, blow threw the hose and use carb cleaner to make sure the banjo bolt is clear, replace if needed.
I have found they rust and then clog but you can save them by taking a small drill bit and hand turning it in the holes and using a wire brush to clean them up.
Then blow them clean with carb cleaner, once dry replace.
I check mine once a year as part of my spring maintenance.
Old Jul 10, 2010 | 09:23 PM
  #23
Originally Posted by Silver_Slug
what are peoples favorite engine oil? and what type 10w-30? 5w-30?
I use Shell Rotella 15w-40 in the summer and 5w-40 in the winter.
Depending on where you live those are the weights I recommend.
Old Jul 11, 2010 | 12:13 PM
  #24
discomedic4's Avatar
I live in Texas and with the heat I have been running the 15w-40. It is working really well for me and is cleaning the engine really well too. Just changed less than 2000 miles ago but it is getting pretty dark again (PO did **** poor job taking care of the old girl so I am playing catch up). I plan on going with the same thing when I change again in about 1000 miles.
Old Jul 12, 2010 | 07:22 AM
  #25
Silver_Slug's Avatar
hmm cool i just finished my 60k maintenance yesterday. My transmission sounds worst. dexron 6 vs dexron 3???
Old Jul 12, 2010 | 08:22 AM
  #26
Dexron 3 or 4, I have heard but do not know for a fact that Dexron 6 is a totally different formulation of Dexron and is not backwards compatible but like I said, I dont know.
Old Jul 12, 2010 | 08:29 AM
  #27
Google is your friend.
http://www.gminsidenews.com/forums/f...-vi-6-a-64757/
http://www.dieselplace.com/forum/sho...d.php?t=182090
Old Jul 12, 2010 | 08:38 AM
  #28
hmmm yeah i figured on the plus side since i did the maintenance i got 18 mpg with ac on from NH to boston last night.
Old Jul 12, 2010 | 08:54 AM
  #29
Isint it amazing how a little TLC will save you gas?
Old Jul 12, 2010 | 08:58 AM
  #30
it has always been the case. now i just need a new 4th gear.
