It gets better, The shop couldnt try anything because it could not access OBD 2.
Old Sep 21, 2010 | 06:29 PM
  #61
rhino_e28's Avatar
They check both of the following here in California,
1. Steady idle
2. OBD communications.
Originally Posted by Spencerfitch
I don't see what smog has to do with anything, unless it's setting your cel off. Mine hardly comes on and when it does I just clear it. Just got my inspection done this weekend
Old Sep 21, 2010 | 09:27 PM
  #62
rhino_e28's Avatar
Update:
I am going to try a new plan of attack.
I am going to hook up a temp OBD 2 wire. I am only going to wire Power, Ground and the 2 wires directly to the ecu. Fresh wire means no chance of anything else interfering.
Any one have any ideas?
I am also going to recheck all my fuses for the millionth time.
Any other ideas?
Old Sep 22, 2010 | 07:09 AM
  #63
Spencerfitch's Avatar
Sorry for not answering your call last night I was doing a range rovers brakes.
Don't know why I forgot of course they test your obd my bad.
Old Sep 22, 2010 | 07:38 AM
  #64
okdiscoguy's Avatar
Originally Posted by rhino_e28
Update:
Any other ideas?
Did you try the ABS blink test?
Old Sep 22, 2010 | 07:44 AM
  #65
okdiscoguy's Avatar
Pin 8 - alarm
Pin 16 - fuse 3
Pin 13 - airbag
Pin 4 - ground
Pin 5 - ground
Pin 7 - ECU with lead to ABS
Pin 15 - ECU With lead to ABS
You could be onto something here. The comm leads also have jumpers that go to the ABS ECU. They show to be the same color going to pins 13&14 of connector C2084 of the ABS ECU. Try the blink test to see if you can access the ABS ECU.
Old Sep 22, 2010 | 11:49 AM
  #66
rhino_e28's Avatar
I think the blink test works, I was checking all the wiring and the ABS light started to blink OH:. So I think connection to the ABS brain is ok. Any other ideas? should I still try a direct wire? I have a extra ecu. I tired it but the car wont start with it. I imagine it has to do with the alarm brain.
This truck has to many brains for its own good.
I thought I would post this for a reminder of why I am still trying. This truck is a blast even with stock suspension.
Old Sep 22, 2010 | 02:26 PM
  #67
okdiscoguy's Avatar
When you replaced the ECU, did you try to read it with the scanner? Plug it in and see if it will read. I know it won't start, but if it reads, you can swap ecu's at the shop and have everything re-programmed then.
Old Sep 22, 2010 | 02:40 PM
  #68
rhino_e28's Avatar
I believe we tried with no luck to read the new ecu...
Old Sep 22, 2010 | 03:27 PM
  #69
okdiscoguy's Avatar
sounds like jumpers it is.....
Old Sep 22, 2010 | 04:11 PM
  #70
rhino_e28's Avatar
Can I just wire the ecu and power and ground and eliminate the abs for my test?
