It gets better, The shop couldnt try anything because it could not access OBD 2.
Old Sep 21, 2010 | 12:03 PM
  #51
okdiscoguy's Avatar
That means it is working right. Cold idle is higher than warm.
Old Sep 21, 2010 | 12:09 PM
  #52
Spencerfitch's Avatar
Im empty! All I can say is if the dealer wantsmore than it's worth it may not be worth much and unplugging the iacv whould be perfectly fine.
Old Sep 21, 2010 | 01:00 PM
  #53
Cosmic88's Avatar
Originally Posted by okdiscoguy
, if you moved the tps or IACV, it will need to be reset. .
no cigar for you...
.... The Idle air control valve is self-resetting. Each time you turn off the ignition... when you "cut" the voltage to the ECU, the unit sends out a signal to the stepper motor to wind it fully backwards and allow maximum air into the plenum chamber. You should hear a buzz from the stepper motor as the engine dies. As the ignition voltage is "cut", the engine simply stops with the stepper motor in maximum air position.
Old Sep 21, 2010 | 01:11 PM
  #54
rhino_e28's Avatar
I am in California and have smog approaching soon
Old Sep 21, 2010 | 02:49 PM
  #55
okdiscoguy's Avatar
Originally Posted by Cosmic88
no cigar for you...
Should work that way, but it doesn't. If you don't believe me, go pull your IACV and mess with the plunger. Having a 95, it may be different, but 90% of people on here that have replaced their IACV have had to go to the dealer to have it reset.
PS, I don't smoke..
Old Sep 21, 2010 | 02:57 PM
  #56
rhino_e28's Avatar
I am unable to find a shop I trust in the bay area, I have called 15 shops, 4 said to take it to the dealer.
Old Sep 21, 2010 | 03:13 PM
  #57
Cosmic88's Avatar
Default NO smokin'!
ok then... no ice cream for you.
Please don't think I was being nasty with you... text is so easily misunderstood.
As for the IACV... I've had them out many times from various model years. Mostly for cleaning / lubing and I'm fairly familiar with them. When you pull it out and completely / securely blank off the hole in the plenum (at idle rmps) you should be able to switch off the engine and cause the cone plunger shaft to withdraw fully into the motor housing. If this is not happening the plunger itself may need lubrication or it could just simply be dead, the ECU could be bad or you have a bad connection between the plug and the ECU in the harness. Nothing else beside the ECU controls the IACV after the engine is switched off.
So, all I am saying is, if the ECU getting reset by a stealership cures the problem then it was not the IACV at fault... t'was the ECU.
Old Sep 21, 2010 | 03:25 PM
  #58
rhino_e28's Avatar
Old Sep 21, 2010 | 05:04 PM
  #59
okdiscoguy's Avatar
I understand what you are saying, and you can take them out and watch the plunger move. All I am saying is that if you move that plunger yourself, the ECU will not read it right. It thinks it is in a certain position, and it is somewhere else. Same with the TPS. It is always programming the ECU to calibrate for the new part. You can take them off and clean them, but move one from another truck and it will idle funny until the values have been set in the ECU.
I didn't take your post as crappy...I also do not advocate taking it in for anything. But no comms with the ECU via OBD2 port needs a hands on tech IMHO..
Still doesn't solve the OP's problem, though.
To the OP, does your anti-lock light come on? Just to check ECU comms another way, ground pins 5 and 15 to do the ABS blink code test. There is a full write up for it in the tech section.
Old Sep 21, 2010 | 05:27 PM
  #60
I don't see what smog has to do with anything, unless it's setting your cel off. Mine hardly comes on and when it does I just clear it. Just got my inspection done this weekend
