Getting Transmission Pan Out
So I've got a '98 Disco that lost a front drive shaft. It trashed the end of the shaft, smashed the floor pan a bit, dented the transmission pan and crushed the dipstick tube. I got all the parts at the junk yards a couple days ago and started tearing in today.
Here's my problem: I can't get the transmission pan out. I pulled the bolts for the crossmember and tried to slide it down enough for the pan to clear the valve body, but there's not enough room between the member and the exhaust.
Any ideas? I really don't want to drop the entire exhaust just for a transmission pan. I mean I've worked on some nasty cars before, but there's gotta be a better way to get this pan out.
So much for a bargin
Got all the parts for $58 and by the time I deal with busted exhaust studs, 3 flange gaskets and a whole bunch of busted knuckles it'll be a 3 day job and cost over $100.
Don't even get me started on the fact that to replace the flange bolts at the transfer case I have to pull the drive flange. I'm starting to dislike this thing...
Got all the parts for $58 and by the time I deal with busted exhaust studs, 3 flange gaskets and a whole bunch of busted knuckles it'll be a 3 day job and cost over $100. Don't even get me started on the fact that to replace the flange bolts at the transfer case I have to pull the drive flange. I'm starting to dislike this thing...
You can replace the downpipe flange studs with a regular nut/bolt.
Once I got over the depression of such a small job getting so out of hand, I got to pulling the exhaust. With the pan lowered I can see the pan was not the reason (or not the only reason) for the leak.
On the top side of the flared out section of the transmission where the pan and valve body and such go, there is about a 2"x3" oval chunk of transmission MISSING. I test drove this truck before digging into it and the transmission seemed fine, so that leads me to believe the hole is superficial.
Anyone know a way to do some kind of patch or something? Or is this transmission just a goner?
I can't really get a good pic with it still in the truck, but I grabbed a stock pic and highlighted the approximate location, size, and shape... and the missing piece is no where to be found. I'm sure it's on the side of the freeway back in Texas somewhere.
