GM Radiator Swap, 'Merica!
Old Jun 10, 2015 | 06:51 AM
  #131
MM3846's Avatar
Originally Posted by TOM R
i knew soneone here bought that, was welded upside down or something right?
Nothing lined up.
Old Jul 1, 2015 | 06:21 PM
  #132
Shiftonthefly1's Avatar
I'm going to resurrect this thread. My new to me Disco is in need of a radiator. This thread has my seriously considering going with
2002 S10 Radiator
Aftermarket EOC
Not sure on TOC. The stock cooler and the one in the new rad seems to be more than an S10 had. Possibly delete radiator option all together and get RR P38 cooler or aftermarket.
Old Jul 2, 2015 | 05:49 AM
  #133
drowssap's Avatar
make sure you get 4.6 p-38 coolers they have six cores, 4.0 only have 4 cores
Old Jul 2, 2015 | 06:06 AM
  #134
nuclearw's Avatar
2002 S10 Radiator
Aftermarket EOC
S10 rad would not be bad.
Amazon.com: Hayden Automotive 1230 Heavy Duty Oil Cooler: Automotive Amazon.com: Hayden Automotive 1230 Heavy Duty Oil Cooler: Automotive
Looks nothing like this... but this cooler is the perfect size.
Amazon.com: Derale 15719 Fluid Control Thermostat Kit: Automotive Amazon.com: Derale 15719 Fluid Control Thermostat Kit: Automotive
this guy fit perfectly.. got some stainless screws from home depot, drilled a couple holes in the support for the coolant overflow tank, and mounted this below.
Find a local source for the 1/2in ID hydraulic line, i got 10ft as my routing was a little wierd... will re-do the routing when I change out the condenser core
I gotta pull pics off my old work phone... i'll try to remember to do that today.
Old Jul 2, 2015 | 06:33 AM
  #135
antichrist's Avatar
2002 S10 Radiator
Aftermarket EOC
If the tanks are good you can get it recored with a HD core. If you take care of it after that it will outlive the truck.
Lack of maintenance is what causes peoples' radiator problems.
Old Jul 2, 2015 | 06:46 AM
  #136
fishEH's Avatar
The cost of recoring will be more than an S10 setup and even more than an EBay aluminum Rover radiator. I had my genuine radiator recored in 2010 and it was $365. At the time it was the cheapest option available.
Also, I had a hard time finding a place that would recore. Our of about 4 local shops only 1 actually knew how to do it or would do it. And even he questioned how economic recoring would be versus buying a replacement. That was until he looked it up and saw a genuine was over $700.
Old Jul 2, 2015 | 08:29 AM
  #137
Exactly. The two shops that do it here didn't want to touch it because the tube diameter is so small. If it were 365 and I never had to worry about it again I might think about it.
I was thinking about running the S10 set up because it sounds like it's an upgraded system for cheaper than a stock replacement. It gets rid of the stupid lower hose. And adds a regular cap to allow easier bleeding. If I go with external coolers, it sounds like the cooling capicity of the radiator would be greatly improved.
Old Jul 2, 2015 | 02:59 PM
  #138
TOM R's Avatar
my last price from several shops was around 500 for hd recore of the stock
Old Jul 2, 2015 | 07:17 PM
  #139
antichrist's Avatar
Yeah, but it's a drop in swap, no mods needed (other than having a petcock drain. Plus you don't have to worry about plastic tanks getting brittle and cracking. There's a reason people replace the plastic plugs on the stock radiators with brass plugs. Cheaper doesn't always mean better.
The only aluminum one I'd consider is one of the ones that's 100% aluminum, including the tanks, but they are in the $700-$900 price range.
To each their own though.
Old Jul 4, 2015 | 12:22 AM
  #140
Does any one know the specific application for the lower hose? Thread mentioned something about a chevy 3500. But no engine size. Diesel. Gas. Big block. Small block. All look like different hoses. Or maybe a part number?
