Got push bar on now want a WINCH :D
Old Mar 20, 2011 | 10:49 PM
dreamspawn's Avatar
Default Got push bar on now want a WINCH :D
Well got my push bar/brush guard on, now looking at winches anybody have any recommendations, honestly probably not get in a situation where i need but just in case. I've heard lots of ppl says get a 3,000lb and double the cable and that will be ok but that is guys here with c/k 10-15s,dodge pickups etc...
Also if somebody could post the write up about how to get the 4wd shifter to work on all 4 again. Mine is stuck on 4 open h and can get 4 open l but it take alot of shaking and pushing.. i know there was a write up how to get it all working and going..
Old Mar 21, 2011 | 06:36 AM
tweakrover's Avatar
have you tried to shift it while rolling slowly, thats how i do mine, its really hard while sitting still.
Old Mar 21, 2011 | 08:24 AM
hilltoppersx's Avatar
get under and spray the crap out of it with some penetrating lube and keep working it and like said above try rolling 5mph or under.
as for winch, what type of brush guard did you install? the stock one? if so you will need a winch tray. where are you located? i have one for sale.
Old Mar 21, 2011 | 09:25 AM
You are going at the winch/brush bar thing all bass ackwards. Why throw on a brush guard then think about mounting a winch, especially a 3000 pounder that isn't worth the time of day.
Are you going to add a winch tray or use a steel bumper? Don't go lighter then an 8000 pound winch, should use a 9500 for the weight of your truck.
Old Mar 22, 2011 | 12:57 PM
dreamspawn's Avatar
I have tried while rolling and it wont even budge to the left i guess i'll have to get under and start spraying, and give it a go..
Old Mar 22, 2011 | 01:19 PM
Chris-bob's Avatar
General rule of thumb...get a winch that does twice your vehicle's weight. That will account for the increased forces that are holding your vehicle immobile(mud, ravine, rocks, jeeps)
Old Mar 22, 2011 | 01:23 PM
jafir's Avatar
Are the jeeps holding you back?
Old Mar 22, 2011 | 01:46 PM
Chris-bob's Avatar
Yes. Sometimes when I am driving over them, my tires get stuck in the roll cages. A winch would help with this problem.
Old Mar 22, 2011 | 04:49 PM
tweakrover's Avatar
the rolling trick is only for between high and low
lighting
Mar 27, 2015 09:46 PM
95_rover
Oct 30, 2012 04:52 PM
jacumja
Apr 30, 2011 02:12 AM
perkj
Apr 26, 2011 10:34 AM
Long Haul
Sep 5, 2010 03:50 PM
