Guess and Win a Prize
Ok check engine light came on drive home from work - haven't checked the scanner yet - guess what it is and win a prize
96 D1 SD
All maintenance is up to date
110K miles - all original vehicle no mods
Did not just buy gas
Will scan tomorrow and let you know the code
96 D1 SD
Interesting turn of events - new battery installed by AAA under warranty couple of days earlier - young mobile tech sprayed the red battery corrosion protection on the posts before installing the clamps and then on the clamps - code reader also said low voltage which actually does not give a code - which come to find out can actually cause a 1172 code - so didn't need to throw new MAF and clean injectors and replace O2 sensors - all a shop could have done for thousands $
these are crazy rigs
Yes that is exactly what it did - caused a slight drop in voltage on the "ON" position thus causing the ECU to toss off the 1172 code - once the posts were cleaned and clamps reinstalled the service engine light went out after a few driving cycles - low voltage plays havoc with the ECU causing lots of things from check engine lights to anti-theft issues
