Hazard Lights Just Came On
Old Nov 3, 2012 | 11:29 AM
mikeincali's Avatar
5th Gear
Default Hazard Lights Just Came On
I turned on blinker and hazards came one, and wouldn't turn off. Tried fuse, battery connection. Finally, when I restarted the vehicle, they went off. Now I'm hesitant to use blinkers again.
Any advice.
Thanks.
Old Nov 3, 2012 | 07:29 PM
ihscouts's Avatar
Did you hit a bump at the time you turned your blinker on? If so your inertia switch set the hazards off, not the turn signal.
Old Nov 3, 2012 | 10:02 PM
mikeincali's Avatar
5th Gear
So was it just a fluke, or should I change the switch?
Old Nov 4, 2012 | 12:01 AM
wheelgarage's Avatar
The switch contacts/plastic pieces/internal springs might be going bad. If you switch it back and forth and it fixes it, then the switch is going bad...
J dog
Feb 10, 2021 10:14 AM
joeschuer
Mar 7, 2012 07:58 PM
Heybuck59
Apr 2, 2009 08:35 PM
pilsner
Nov 27, 2008 08:05 PM
darkside
Aug 22, 2007 04:06 PM
