Head Gasket
Old May 5, 2015 | 01:57 PM
cobra29's Avatar
Default Head Gasket
Finally have some time to tackle this bad boy. Might need some help as I get deeper
Old May 5, 2015 | 02:03 PM
cobra29's Avatar
Default Head Gasket
Attached Thumbnails Head Gasket-img_20150505_145032.jpg   Head Gasket-img_20150505_145109.jpg   Head Gasket-img_20150505_145148.jpg   Head Gasket-img_20150505_145318.jpg
Old May 5, 2015 | 04:46 PM
cobra29's Avatar
Do I need to remove the injectors to get the intake out? I have all the 12 bolts (6 per side) out and it's not budging...
Old May 5, 2015 | 05:27 PM
green-lantern's Avatar
Originally Posted by cobra29
Do I have remove the injectors to get the upper intake out? I have all the 12 bolts ( per side) out and it's not budging...
Nope, just need to make sure to pull all the bolts and fuel lines etc. Mine was a bit hard to budge (I just did it a week ago). Tap with rubber hammer and pry easy and it should start breaking loose.
Old May 5, 2015 | 10:35 PM
cobra29's Avatar
Thanks, I was able to get it out with some man handling. I found this on the left head. Any idea what it is or where it came from?
Attached Thumbnails Head Gasket-img_20150505_205938.jpg   Head Gasket-img_20150505_205953.jpg
Old May 5, 2015 | 11:26 PM
USNAVYORDNANCE's Avatar
From the valve cover gasket. Has 4 per side.
Old May 6, 2015 | 08:03 AM
cobra29's Avatar
Yep, sure is. Thanks.
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
jpmiller
Sep 26, 2012 06:32 AM
dancedisco
Feb 6, 2012 06:34 AM
jcostello
Nov 2, 2006 10:28 PM
