heat and air only works on setting 1 and 3?
Old Jul 15, 2010 | 10:31 PM
anything old's Avatar
Damn i would have just thrown a resistor at it. In my experience 99% of the time its the resistor pack but thats with gm cars. I could be wrong here but i ran across a silverado ONCE that i pulled the fan speed selector **** off of and coated the contact points with a lead pencil and it fixed the problem, might be worth a try.
Old Jul 16, 2010 | 02:18 PM
Classklown90's Avatar
thanks guys, thanks guys and since ill be replacing this, there is no way to mod the digital d2 one in there is there?
Old Jul 16, 2010 | 04:28 PM
Danny Lee 97 Disco's Avatar
I would try spraying it down good with CRC Contact Cleaner or something of that sort. Might be a cheap fix.
Old Jul 16, 2010 | 06:22 PM
Silver_Slug's Avatar
Originally Posted by Classklown90
for some reason when i put my air/heat on 2 or 4 it does not blow anything out but when i put it on 1 and 3 it works fine. any clue as to why?
Most of the time unfortunately you need a new blower. It happens with variable speed motors. My BMW has the same thing accept only 1 and 4 work so its either a little air or a lot of air. i think my LR only works on 1,2, and 4. It happens with older cars. Think about it you use that motor almost every single time you drive you car.
Old Jul 16, 2010 | 06:25 PM
i guess i have no idea what im talking about just with the BMW we normally replace the blower set up.
Old Jul 16, 2010 | 07:20 PM
The contacts on the blower switch get dirty and old and worn out.
Usually the fix is a new HVAC panel.
I ahve yet to hear of a DI HVAC fan going bad, not to say it does not happen, I have yet to hear of it.
Old Jul 16, 2010 | 09:11 PM
spike is probably right!
Old Jul 18, 2010 | 06:53 AM
alright thanks, ill try cleaning the contacts before replacing it
Old Nov 11, 2010 | 01:07 PM
losinov's Avatar
Default only 4 works
Hey guys,
So I read all the posts and I'm thinking that the problem I am having is related with the contacts on the blower. Basically my fan only comes on when I put it on 4. I can hear a clicking behind the glove box when I put it on any setting but no response from the fan... Any ideas guys?
Thank you
Lev
Old Nov 11, 2010 | 05:44 PM
Originally Posted by losinov
Hey guys,
Thank you
Lev
Bad HVAC fan speed switch.
You either need to pull it out of the dash and try and clean the contacts or replace the HVAC control unit.
