heat and air only works on setting 1 and 3?
Old Nov 12, 2010 | 01:16 AM
  #21
losinov's Avatar
any instructions online on how to do that? Thank you
Old Nov 12, 2010 | 02:23 AM
  #22
Long Haul's Avatar
Originally Posted by losinov
Hey guys,
So I read all the posts and I'm thinking that the problem I am having is related with the contacts on the blower. Basically my fan only comes on when I put it on 4. I can hear a clicking behind the glove box when I put it on any setting but no response from the fan... Any ideas guys?
Thank you
Lev
I had the same problem with mine ad it ended up being the resistor pack. The resistor is located under the passenger side of the dash in the duct pipe just downstream of the fan. Once you find it you can use a test light or multimeter and go through all postions of the switch seeing if you are getting any power through it. Since your fan is only working on 4 (high speed) it bypasses the resistor and puts full power to the fan. Im not saying its not the switch either but its a good place to start.
As far as instructions download the rave manual it has the schematics and has removal/replacement procedures
Old Nov 14, 2010 | 05:57 PM
  #23
losinov's Avatar
Thank you guys will try both the contacts on the switch and finding the resistor pack.
Rover Chris
Oct 3, 2009 04:22 PM
H Hill
Feb 4, 2009 07:00 PM
Street Wolf
Jan 17, 2009 07:00 PM
whurst79
May 31, 2008 05:20 PM
chenderson
Sep 21, 2007 07:37 PM
