Heater blower and windows stopped working 98 discovery
Old Jan 25, 2011 | 10:59 PM
yfdreserve's Avatar
Question Heater blower and windows stopped working 98 discovery
New to this forum not sure I am doing this right. I have a 98 land Rover discovery. The windows and blower fan suddenly stopped working. Have checked fuses under dash and below steering column all are fine. Suggestions?
Old Jan 26, 2011 | 07:43 PM
I am moving you to the DI section.
Do any of the windows work?
Have you tried wiggling the fan switch?
Old Jan 26, 2011 | 09:06 PM
yfdreserve's Avatar
Default windows and blower not working
Yes and none of the windows are working
Old Jan 26, 2011 | 09:20 PM
Henrici's Avatar
Jesus you are in Yakama and your heater doesn't work!!! Do they make 12v portable heaters? So they both stopped working at exactly the same time?
Old Jan 27, 2011 | 02:22 AM
yfdreserve's Avatar
Default window and blower stopped working
Both the heater and the fan stopped at the same time. Have checked fuses under Hood, steering column and seat. None of the windows are working.
Old Jan 27, 2011 | 07:44 AM
Cosmic88's Avatar
When you inspected the fuses was it visually or with a multimeter / continuity test? Fuses 11 and 12 (under hood) in bank A control window lift ecu and blower motor. Since you say they went out at the same time I would start by checking that fuse and its wiring connections. just a guess...
Old Jan 27, 2011 | 09:08 AM
yfdreserve's Avatar
Default windows and blower stopped working
We visually checked the fuses. I took it to a mechanic and they looked at it for a couple of hours. Not sure if they did that. I live in yakima, Washington and there are only two mechanics here that will touch land rovers. I will check them today to be sure. I had no issues with anything prior. I was driving and all of a sudden the blower stopped. It was cold and the windows fogged up that's when I noticed that the windows were not working either. Everything else is fine.
Old Jan 27, 2011 | 10:41 AM
WaltNYC's Avatar
Sounds like a scene from a Cheech and Chong movie! Sorry to have a laugh at your dispense. Please don't be offended.
You've come to the right place for help.
Have you tried new fuses? Just in case your visual inspection didn't catch a minor defect?
Old Jan 27, 2011 | 09:18 PM
yfdreserve's Avatar
Fuses are good. Ready to pull my hair out, LOL.
Old Jan 27, 2011 | 10:18 PM
Long Haul's Avatar
Does the fan work at any speed? I would make sure the blower motor didnt die.
