Help - Antenna Is Dangling!
Old Dec 25, 2012 | 01:01 PM
evoking's Avatar
Default Help - Antenna Is Dangling!
So the radio antenna is so loose it is now sticking out sideways from the car. Yet there is no easy access from under the hood. How exactly do I tighten or replace it?
I did notice the radio stopped working a few months ago so I'm assuming the cord came loose as well. We just use IPOD so never really cared. But now it is looking bad. Is there a way to remove/unbolt from topside?
Old Dec 25, 2012 | 05:17 PM
fishEH's Avatar
I think you need to pull the fender off or at least remove the upper Phillips head screws and pull the fender out.
Old Dec 25, 2012 | 08:48 PM
Banzai Jimmy's Avatar
Yep, most of the top phillips head screws starting at the windshield and to make it easier go ahead and remove the bolts (?) that run down the side in the door jamb. If you've never had your fender loose, you'll have to pry it apart at the top from the sealant/goo.
Old Dec 28, 2012 | 08:35 AM
evoking's Avatar
Boy that realy stinks if removing the fender is rrquired just to replace the antenna!
Old Dec 28, 2012 | 09:20 AM
pinkytoe69's Avatar
You may not have to remove the fender.
Removing the top screws and bending it out a little should give you enough space to work with the antenna.
Old Dec 28, 2012 | 09:38 AM
Yeah, a full removal is not necessary. You have to remove enough fasteners along the top and jamb to create enough room at the top, rear of the fender to fix it. It's still a lot of work just for the antenna.
Old Jan 2, 2013 | 06:35 AM
jbunner's Avatar
Atlantic British has replacement antenna and instruction page, you might want to look at that.
moda27
Freelander
Oct 21, 2014 06:56 PM
FlippinDisco2003
Jan 2, 2014 11:51 AM
Ludovic
Apr 27, 2013 07:38 AM
adowgiert
Audio/Visual Electronics
Oct 31, 2005 05:17 PM
mikemeyer0
May 26, 2005 01:44 AM
