Help Diagnosing a Bad Brake Booster? Common failure?
Old May 20, 2021 | 05:17 PM
Dubiousgarage's Avatar
Default Help Diagnosing a Bad Brake Booster? Common failure?
Hi all, new to Discoverys but I’ve been a series rover person for 35 years. Just got a 94 D1 that’s been in a super hot climate.
I’d love some help diagnosing a potential bad brake Booster. They’re pretty expensive so I don’t want to buy it just to see if it fixes the issue.
There is a very loud constant hissing (like a very bad vac leak) suddenly coming back of the engine right side. If I unplug the vac line that goes to the brake booster (and cap it on the manifold) the sound stops. The sound is not when I press the pedal it’s all the time.
I just redid the whole hydraulic brake system including the master cylinder and everything seemed ok. Then the sound started. I was guessing I cracked the booster diaphragm while bleeding the system and then diaphragm it failed shortly after?
BUT! I found an older thread discussing an o-ring while installing the master cylinder ??? I did not install any o-ring between the master and booster. Is one needed? Could that be the leak?
The older thread also mentioned a yellow plastic tube on the master cylinder. The new one came with one that I removed. I thought it was a shipping protection part and not on the old cylinder. Was that required?
Thanks for any advice. Not sure if failing boosters are common on discos— Don’t want to buy a new boaster if I just needed an o ring.
Old May 20, 2021 | 11:15 PM
Icannap1's Avatar
The plastic cone and o-ring that goes around the base are needed, If you threw it away it can be purchased again as kit.
zappy
May 20, 2021 12:43 PM
elboy0712
Dec 6, 2019 10:43 PM
romulus prime
Mar 3, 2016 08:40 PM
bosshogt
Jun 3, 2013 11:07 AM
colton
Dec 10, 2007 12:14 PM
