Help! ECU loses power when rainy
Old May 31, 2016 | 09:03 AM
TOM R's Avatar
A shorted sensor will suck power been there, had the tank pressure switch short and killed TPS voltage, that was fun to diagnose
Old May 31, 2016 | 10:40 AM
ihscouts's Avatar
I remember, the initial problem was with the TPS. Without seeing the wiring diagram I would've never imagined the fuel tank pressure sensor being tied toether with the throttle....
Old May 31, 2016 | 08:17 PM
NickAdams's Avatar
Check out my thread on the DII side: long story short, I had ECU problems. After moderate scrub of connectors, I attacked all sockets on ECU with an entire can of CRC contact cleaner. The good, plastic safe stuff. After seeing one small fleck of corrosion come out of one socket, everything worked great.
Old Jun 3, 2016 | 07:30 AM
GRAVZZY's Avatar
It's been pretty rainy for 2 days now and I have not been stranded yet. I'm still not too sure I'd take the road with the children... I've spotted than recently I hear a relay tripping under the glovebox when the pavement is extremely corrugated (which is frequent in Quebec and other northern communist countries). This symptom might be related... I've kept on looking for harness damage and dirt in connectors but still nothing convincing... It makes me want to do a diesel conversion even more! Putting a non sealed ECU in the engine bay of an offroad vehicle is just plain dumbness, the components were better protected in every compact car I had before.
Old Jun 3, 2016 | 07:56 AM
TOM R's Avatar
None of the sensor connectors are sealed, clean , dielectric grease them, check for loose grounds, no ground no power
Bumpy roads and clicking relays sound like loose ground or loose connection
GRAVZZY
May 29, 2016 08:26 AM
Alabama Butthead
Oct 11, 2014 03:00 PM
chief78
Dec 4, 2012 01:53 PM
discoken
Mar 25, 2009 09:30 AM
christians1600
Mar 18, 2008 09:33 AM
