Help .head light problems 1997 disco 1
Old Nov 20, 2013 | 06:23 PM
Soccer Dad's Avatar
Default Stalk switch failure
It seems LandRover was too cheap to do the job right. The stalk switch contacts fail routinely. There is too much current going by.
The smart thing is to rewire with 2 relays where the stalk switch controls the appropriate High/Low relays and the relay handles the current.
Easy for me to say because I know how to do it.... but really, it's not that hard
SD
Old Nov 20, 2013 | 06:43 PM
wrongway1's Avatar
SD
Do you think that's why I get that occasional flicker running through the forest at night? It happens every once in a while, but the volts and dash lights don't reflect a dip in power when the lights flicker.
Old Nov 20, 2013 | 07:17 PM
disco1tim's Avatar
4wd High
Ok update
I just received the new stalk switch ... Perfect runs great every thing is working great thanks guys .
Ok so looking back on it the wife and I were out on a drive one night stopped for a bit then the low beams would not come on so we drove home with high beams this should have been a sign that it was going out.
Also I have a Haynes manual for the rover and it shows a relay. I now know that the the wiring diagram is in correct.
Once again thanks for all the great help every one .
Old Nov 20, 2013 | 08:36 PM
abran's Avatar
Now you can repair your old one and have a spare(or sell it for big bucks on Ebay!).
Old Nov 21, 2013 | 01:28 PM
WaltNYC's Avatar
Originally Posted by disco1tim
.... the wife and I were out on a drive one night stopped for a bit ......
Hold on! It sounds like you are leaving out the good part!
Old Nov 21, 2013 | 10:50 PM
disco1tim's Avatar
4wd High
Lol got it !!! Yes there where headlights but there was also no lights ... Haha
Old Nov 22, 2013 | 12:20 PM
wrongway1's Avatar
Please look at the schematic in the RAVE circuits manual, and tell me the relay you see. I don't see one. The stalk switch is probably bad, turn steering wheel 90 degrees to get at the mounting.
Savannah, there's a wiring schematic for the DI?? Can you send me the link? I don't seem to be able get the one you embedded in your post to work. Thanks!!
Old Nov 22, 2013 | 01:33 PM
abran's Avatar
Default Rebuild light stalk
Ok, I got a request to illustrate how to rebuild the light switch. This is my first attempt at a tutorial, so go easy on me.
Attached Thumbnails Help .head light problems 1997 disco 1-switch-1.jpg   Help .head light problems 1997 disco 1-switch-2.jpg   Help .head light problems 1997 disco 1-switch-3.jpg   Help .head light problems 1997 disco 1-switch-4.jpg   Help .head light problems 1997 disco 1-switch-5.jpg
Old Nov 22, 2013 | 01:35 PM
abran's Avatar
Default Final page
Here is the final page.
Don't forget to re assemble and install!(probably didn't need to say that).
Old Nov 23, 2013 | 08:18 AM
DiscoJag's Avatar
Talking Stalk
Thanks ! Maybe that should be a sticky or FAQ. It seems the same things go wrong with these trucks, eventually. Fortunately, they can be fixed !
