help with identification
Old Jul 11, 2010 | 01:28 AM
10ECRover's Avatar
6th Gear
Default help with identification
Inherited 96 Discovery from brother. No experience with these vehicles at all. Has 133,000 miles on it. He probably ragged it to pieces, runs awful. After getting on here a month ago found out I need to use premium and have been since. Brother probably never did. CEL and SEL on. Took to Autozone, got codes p0307-misfire cylinder 7 and p1316 excessive emissions. Spent 2 hrs on hear earlier reading threads about these codes. Am going to order magnacore wires and install Bosch +4 plugs after all my reading. Hope that is a step in the right direction. Took a look under the hood and couldn't identify some parts. Took pics and would appreciate any help with identification. The first pic is of a vaccum? hose coming out of the firewall, it has a splitter on it, one hose runs along the drivers side panel to nothing (have no clue where it should be hooked up), the other hose runs to the thing in the next picture. The last picture is of something on the passenger side of the vehicle. Thanks for any help!
Tanya
Attached Thumbnails help with identification-7-10-10-006.jpg   help with identification-7-10-10-007.jpg   help with identification-7-10-10-008.jpg
Old Jul 11, 2010 | 03:23 AM
jbriggs's Avatar
The first is pretty blurry, is it just in front of the master cylinder? Second one is the cruise control. Third I don't know, I don't have one of those on mine.
Old Jul 11, 2010 | 09:09 AM
The first 2 are cruise control vacuum lines, it runs through the fire wall and to the brake pedal, if the cruise is not working then a leak in this line is the #1 suspect.
okdiscoguy's Avatar
first pic is the cruise control tee fitting. One line goes through the firewall to the brake switch, one goes to the throttle bladder (2nd pic) and one goes forward to the vacuum control unit.. in front of the airbox, tucked away..
Old Jul 11, 2010 | 09:10 AM
As for the red service engine soon light...that light show no codes, it is a emissions reminder and you need to reset it manually.
www.discoweb.org, tech section, "how to reset SES light" DI.
Old Jul 11, 2010 | 10:37 AM
10ECRover's Avatar
6th Gear
Thanks to all that replied. This is not my everyday driver, so do I need to worry about fixing the cruise control? The vaccum line that runs to the front of the vehicle is not connected to anything, will this cause problems with anything if I don't fix it? Thanks for the help!
Old Jul 11, 2010 | 11:04 AM
Rovin4life's Avatar
cut the lines so the cracks are missing and reinstall the t connector. give yourself a little wiggle room so you don't screw yourself. It doesn't have to be completely seated just fit on the edge to draw a vacuum. A mm at least.
and the third picture is the purge valve.
Old Jul 11, 2010 | 12:13 PM
AK Rover's Avatar
Crack vacuum lines for the cruise control won't cause any problems other than the cruise won't work. I didn't use my Discovery as a daily driver but I found the cruise control to be very nice on the long drive to some of the trailheads.
Since no one else has mentioned it, the third picture is part of your emissions system. It is a purge valve for the evaporative loss system. Essentially the evaporative loss system collects the vapor from the fuel tank and sends them to the engine to be burned. The purge valve is there in case pressure becomes too great in the EVAP canister and will vent the excess pressure.
Click on the link in my signature to download the RAVE manual. You'll find it very helpful.
Old Jul 11, 2010 | 01:03 PM
I fixed my cruise with Liquid Tape, been working for 3 years now and I use my cruise EVERY WHERE, even in town, longer than a mile? Cruise.
It will set at 25mph, so that long 25 mph street with the cops at each end...no speeding ticket.
Old Jul 11, 2010 | 07:56 PM
10ECRover's Avatar
6th Gear
Thanks to all for sharing their knowledge! This site is great!
Punter
Defender
Jul 6, 2022 04:57 AM
CRB357
May 12, 2015 07:10 PM
mburnett
Apr 8, 2008 08:59 PM
bigugly82
Dec 22, 2007 02:49 PM
