Help me please wit my disco1
Old Aug 1, 2011 | 07:02 PM
atancreti's Avatar
Originally Posted by Disco Mike
new fuel filter from Advanced Atuo. Let us know what happens.
How do you suggest removing a fuel filter that is severely rusting on the ends. I am worried if I put to much pressure on the line it will break.
Thoughts?
Thanks.
Old Aug 2, 2011 | 06:39 AM
Jull's Avatar
You can use this: Land Rover Fuel Filter Kit & Other Parts For Rovers at Atlantic British
Or you buy clamps, approximately 8 inches of steel fuel line and fittings, if you break something you're able to repair it.
To narrow the possibilities, you can start by replacing the filter, it costs only 10$. The I'd check electric current to the pump to be sure there is no ground issue. And if those don't clear the issue I'd move on to the fuel pump.
Old Aug 3, 2011 | 07:21 AM
atancreti's Avatar
Jull,
When I bought my fuel filter from AB i didn't get the other stuff. Just filter. Thanks
Old Aug 3, 2011 | 07:44 AM
Jull's Avatar
Apart from soaking it in PB Blaster and letting it sit for at least a day, I have no idea. I'd get spare parts needed in case I break something while removing the old filter.
Old Aug 4, 2011 | 10:59 AM
groundandpound's Avatar
My lines broke during teardown. I replaced with some Fuel Injector components I found at NAPA. Bolted right in and has been a breeze ever since.
Since I DID break them, I took the opportunity to re-locate the filter to a more protected location in order to avoid continuing to cake it with mud and water.
Old Aug 4, 2011 | 12:24 PM
atancreti's Avatar
Do you have pictures of that? I would like to do something like that.
D1scoDaz
Jan 31, 2011 05:21 AM
Ranger_bah
Sights N Sounds
14
Feb 6, 2009 02:26 PM
Sean Price
Jan 7, 2008 06:12 PM
englishboyonice
Aug 5, 2005 03:34 AM
