Help!!!! Need To Find Brake Line Kit!!!!
Inline tube The brake plumbing experts
Buy a roll of line and make your own, assuming you are talking about the lines that plumb the whole truck.
Thanks for the info. I bought tubing from a local auto parts guy and made my own lines. Ran new ones from the front to the rear and replaced what I needed as to prevent any more blow outs on the rest of the lines. However I still seem to be leaking a relatively low amount from the ABS block where all the lines connect. I thought my flares were done pretty well. Any suggestions on how to remedy the problem?
worth a shot.
I ISO flared the ends and over tightened a few times. I used non-stainless tubing which bent and flared easily. Could any kind of contamination within the fluid such as dirt/rust be the issue? None of the other flares I made leaked upon inspection. Anythoughts on ditching the ABS block and retro fitting all the brake lines to a proportioning valve?
