Help!!!! Need To Find Brake Line Kit!!!!
Old Aug 17, 2012 | 03:13 PM
Disco28's Avatar
Default Help!!!! Need To Find Brake Line Kit!!!!
Hey everyone I need to find steel brake lines for my 94 Disco asap!! If anyone knows where to get them please let me know. Or if anyone has any info on the fittings for the steel lines that would help as well.
Old Aug 17, 2012 | 03:52 PM
I doubt you will find anyone who makes a kit, best thing you can do is go buy the tubbing and a bender and make your own.
Old Aug 17, 2012 | 04:08 PM
bcbp's Avatar
Do you mean these?
Land Rover Parts, Accessories and Information
Old Aug 17, 2012 | 07:42 PM
Inline tube The brake plumbing experts
Buy a roll of line and make your own, assuming you are talking about the lines that plumb the whole truck.
Old Aug 18, 2012 | 07:06 AM
antichrist's Avatar
https://landroverforums.com/forum/di...79/#post288350
Old Oct 3, 2012 | 07:15 AM
Disco28's Avatar
Thanks for the info. I bought tubing from a local auto parts guy and made my own lines. Ran new ones from the front to the rear and replaced what I needed as to prevent any more blow outs on the rest of the lines. However I still seem to be leaking a relatively low amount from the ABS block where all the lines connect. I thought my flares were done pretty well. Any suggestions on how to remedy the problem?
Old Oct 3, 2012 | 11:31 AM
antichrist's Avatar
Did you make ISO bubble flares using the correct tool, or did you try to make a bubble flare using an inverted flare tool?
Old Oct 3, 2012 | 02:38 PM
jafir's Avatar
here is one: Land Rover Brake Pipe Parts And Kits - Discovery Brake Pipe Kit
Old Oct 4, 2012 | 05:55 PM
ValveCoverGasket's Avatar
my guess is its the flares. sometimes you can get lucky overtightening them though... if you used non-stainless line (im a big fan of the copper alloy stuff, softer and much easier to work with).
worth a shot.
Old Oct 5, 2012 | 08:39 AM
Disco28's Avatar
I ISO flared the ends and over tightened a few times. I used non-stainless tubing which bent and flared easily. Could any kind of contamination within the fluid such as dirt/rust be the issue? None of the other flares I made leaked upon inspection. Anythoughts on ditching the ABS block and retro fitting all the brake lines to a proportioning valve?
