Help with oil change
Old Nov 20, 2017 | 12:07 PM
lrnoob's Avatar
Default Help with oil change
Hi all,
Just bought a '95 Disco. Love it so far, but it needs a lot of work. Started off with an oil change, but I've hit a roadblock already. I can't fit a socket on the oil drain plug, as the exhaust is in the way. It's just a Kobalt 1&1/8" socket and a 1/2" drive ratchet.
This is the smallest socket I could find, at least locally. Is this normal spacing between the pan and exhaust?
Also, any tips for getting the plug off? I tried it with an adjustable wrench, and it seems to be welded on there.
Old Nov 20, 2017 | 12:20 PM
OverRover's Avatar
Yes, that's the normal spacing between the pan and exhaust. Fine Rover engineering.
A 1 1/8" open/box wrench will fit perfect. Avoid the adjustable wrench especially if the plug is stuck... you will round off the plug head. The leverage from a 1 1/8" wrench should be all you need to remove the plug .....BUT....
As for the plug being stuck, once you have a proper wrench ready, hit the plug with a propane torch. You will only need to do this for a few minutes and the heat from a propane torch is all you need. Good Luck!
>> Home Depot has a Husky 1 1/8" (Model HCW118/ SKU 618782) for only $9.49
Old Nov 20, 2017 | 03:51 PM
lrnoob's Avatar
Thank you! I actually went and picked up that behemoth of a wrench, and with a bit of tugging, got it right off. Oil change done! Thanks again!
Old Nov 20, 2017 | 04:09 PM
OverRover's Avatar
Glad you got it sorted! It's true that is one Big A$$ Wrench.
If you didn't already, then next oil change be sure to get a new oil drain plug and washer Grab a few washers because it's a good idea to change them with every oil change.
They don't cost much and you can get them from L8, AB, RN, Rovahfarm, or any LR parts supplier.
Just search the part numbers in the pic.
Paul3221
Nov 25, 2013 12:12 PM
drewski
May 31, 2013 10:50 AM
collin Barrows
Aug 28, 2011 07:13 AM
mwindth
Dec 21, 2010 08:28 AM
tito5590805
Oct 4, 2010 09:11 AM
