help with t-case linkage
Old Feb 26, 2012 | 07:29 PM
scottshack's Avatar
4wd High
Default help with t-case linkage
I had a stuck diff lock. When I pulled everything out I forgot to note if I had it in high or low. I have verified it is not in neutral, but can't drive it more than a few feet in my garage to see if it is in high or low to set the linkage back correctly. Does any one know the linkage position when in either position? It is at 12 o'clock right now.
Old Feb 27, 2012 | 02:34 PM
Danny Lee 97 Disco's Avatar
I have no idea what you nean by it's at 12 oclock now.
The shifter is to the lower right for hi unlocked and moves forward to shift from high to N to low. The same shifter moves left to lock cdl or righ to unlock. Lowest (most rearward) is Hi, centered is N, most forward is low.
There are several pics of the linkage in the link in my signature.
Old Feb 27, 2012 | 03:30 PM
scottshack's Avatar
4wd High
I was referring to the transfer-case and not the linkage as far as position. I have the linkage removed right now. I need to set the linkage back on the gear in the correct position. When I removed the linkage I don't know if I was in high or low. What I was asking is if by looking down where the linkage connects to the T-Case can I tell if I am in High or Low.
Old Feb 28, 2012 | 07:02 AM
turf63's Avatar
If it was stuck before you took it apart it was probably in high. If you had it in low you would remember. If your tcass were stuck in low you wouldn't be able to go over like thirty five mph without pegging your tach.
Old Feb 28, 2012 | 07:09 AM
hilltoppersx's Avatar
not sure im following you... clockwise locks, counter clockwise unlocks. it your linkage doesnt line up then switch to the other gearing. there are only 2 options. this is a binary fix either it will fit or it wont.
Old Feb 28, 2012 | 12:59 PM
Are you referring to the Diff Lock Function and the selector plate ate the bottom of the linkage? If you are, that is opposite, to get mine to engage required CCW rotation of that center nut. If that is not what you are referring to, then disregard this statement.
Also the selection of high N or Low with the tranfer case is by the internal gearing of that shifter is it not? Refr to the pictures in my signature link. Here is a close up of the mechanism during disassembly:
http://rides.webshots.com/photo/2002...02688643sTaPaU
This is high locked position:
http://rides.webshots.com/photo/2028...02688643WkBjiP
Old Feb 29, 2012 | 11:45 AM
scottshack's Avatar
4wd High
Problem Fixed. I gave a terrible explanation of what I was trying to figure out. I should have left the word linkage out of the equation. I was trying to figure out if I was in 4 high or 4 low with all the linkage removed.
yloDiscoII
Jul 2, 2012 10:53 PM
blondebunny
Jan 28, 2011 03:58 PM
yloDiscoII
Sep 7, 2010 10:39 AM
hilltoppersx
May 17, 2010 08:51 PM
discoxd
Apr 25, 2009 10:17 PM
