Hesistation/Stall At Startup.
Old Nov 21, 2010 | 12:51 PM
Spencerfitch's Avatar
Default Hesistation/Stall At Startup.
Im back in love with my rover and will never own anything else DI DII LR3 that is. But thats not to say she doesn't have her own issues.
It does this from time to time.. Seems like a missfire if I ever knew one. But Im not sure how you can tell if its a missfire. No codes or CEL.
It just happened agian at the store and It took a couple of trys to get it to run. At first it started right up and then rpms started dropping and it was really rough and seemed to struggle to idle untill it finally died
Old Nov 21, 2010 | 02:12 PM
1-low fuel psi
2-idle air control valve
3-fuel temp sensor
Does it only happen with a hot start or anytime?
Old Nov 21, 2010 | 05:48 PM
Originally Posted by Spike555
1-low fuel psi
3-fuel temp sensor
it seems to only be SOME hotstarts
Old Nov 21, 2010 | 06:02 PM
Does it ever do it when cold?
Old Nov 21, 2010 | 06:33 PM
id like to say no. But cant be 100% certain
Old Nov 21, 2010 | 07:04 PM
Pay attention to it and let us know how frequent it is and when it happens.
Hard to tell with it being so random.
Old Nov 21, 2010 | 09:36 PM
Danny Lee 97 Disco's Avatar
Have you changed fuel filter since you've had it?
Old Nov 22, 2010 | 10:55 AM
XCELLER8's Avatar
I agree with all above, check the fuel pressure at the rail. You're not going to hurt anything by replacing the fuel filter and cleaning the throttle body / IAC valve ( dont "move" the valve , just clean it ) . But my $$ is on the fuel temp sensor
# ETC6661
Rover Reaver
Jul 2, 2008 12:26 PM
stokiemike
Dec 17, 2007 11:26 AM
eriqcharlz
Jul 3, 2007 09:30 AM
thesearch35
Feb 19, 2007 10:41 AM
wkujesus2
Apr 19, 2006 12:15 AM
