High idle. 1700-2200 RPMs
Old Oct 4, 2010 | 10:12 PM
Chris-bob's Avatar
Default High idle. 1700-2200 RPMs
I know, you've all seen this asked before, but I have to ask because I find no definitive answers in a search. My idle sits at 1700-2200 regardless of engine temp. I can unplug the MAF and the idle will drop to 'normal'(700rpm) for 10 seconds, then it shoots back up(without the MAF plugged back in). I unplug the IACV and TPS and there is no change to idle RPMs. I did clean the intake, throttle body, IACV and MAF with throttle boby cleaner and a toothbrush. No change in idle. Only codes are a P0304(misfire cylinder #4) and a P0316(misfire causing excess emmissions; that's what my scan tool calls it.) New plugs and 8mm wires. I can clear the codes and they will come back after one start and 20 minutes of driving. Tonight I will be checking the manual for specs on the MAF to test it. Any additional insight would be appreciated. 85k miles on a '96 Disco I.
Old Oct 4, 2010 | 10:18 PM
NiteTrain's Avatar
check for vacuum leaks
Old Oct 4, 2010 | 11:10 PM
Chris-bob's Avatar
Hmm, for some reason I skipped that step. Will check tomorrow. Didn't hear any vacuum leak, however. Can't hurt to check.
Old Oct 5, 2010 | 12:05 AM
NiteTrain's Avatar
spray some of that throttle body cleaner around common vacuum leak areas..when the engine revs up you've found your leak
Disco2 MTL
Feb 16, 2015 02:58 PM
Chris-bob
Oct 4, 2010 03:59 PM
RROJ
Jul 2, 2010 11:05 AM
free_kid
13
Feb 3, 2010 12:56 PM
tommytwotone
Aug 6, 2008 10:07 AM
