High Idle after valley pan
Old May 25, 2015 | 10:17 AM
atancreti's Avatar
Default High Idle after valley pan
Hello,
I recently did a valley pan gasket on my 95 DI and now I have a high idle. I checked my vacuum hoses to make sure they were on and not sucking air (sprayed with carb cleaner and listened for different engine sound). I'm now getting a check engine light, and error code 14. I've found that error code 14 is for the coolant sensor, and I noticed that my coolant gauge now goes up to slightly below half and stops. It used to be at exactly half. (I believe I got all of the air out of the coolant system because the heater blows hot and the hoses get nice and warm evenly).
It seems that once I start it, it will idle at around 1200 RPM. Then if I step on the gas, it comes down very slowly to 1200 RPM again. I'm not sure why its doing this. I did remove the lucas sensor thats on the intake manifold when I did the valley pan gasket.
Thanks for any advice in advance.
Old May 26, 2015 | 06:23 AM
TOM R's Avatar
Did you reseal the plenum? Clean the IACV? Check pcv hoses for cracks?
Not sure what else on dizzy model
Old May 26, 2015 | 05:23 PM
ihscouts's Avatar
Check hoses at the IACV for cracks at joints, not having the correct vacuum at IACV will cause it to run high.
wick_60010
Nov 22, 2017 04:25 AM
cmthompson
Dec 15, 2014 05:11 PM
dean52173
Dec 10, 2010 10:08 PM
chad420
Oct 24, 2009 02:51 PM
JimScream
Jan 6, 2009 02:01 PM
