High Octane fuel
Old Jun 27, 2014 | 07:39 AM
HammerFit's Avatar
Default High Octane fuel
Do you guys run higher octane fuel in older Disco's? I've been using 93 octane ever since I purchased the 95 but I wonder if that's really that important with this engine.
Old Jun 27, 2014 | 07:48 AM
fishEH's Avatar
This is like asking what's the best oil.
I run 93 in one disco and 87 in another. PT Schram will tell you he runs E85. I think it's more important bro just pick one grade and stick with it.
Premium used to be $.20/gallon more than regular. Now it's usually $.50/gallon more which starts to add up a lot faster.
Old Jun 27, 2014 | 08:32 AM
jafir's Avatar
The way I see it, is if $0.50 a gallon on gas that is already $3.00 a gallon is going to be a deal breaker, buy a honda accord and drive the disco on weekends, and still put premium in it.
Old Jun 27, 2014 | 09:14 AM
fishEH's Avatar
It depends how much you drive it I guess and what people's situations are. Disco's are not great commuting vehicles, for sure. I drive 20 round trip to work M-F and still burn through a tank every week and a half. I feel really bad for these guys that have 100 mile round trip commutes around me. That adds up quick.
My '98 I've only ever put Premium in since I've owned it since '09. The ONE time I forgot and put Regular in it totally ran like crap and even threw a code I believe.
My '96 was owned by my brother for about 6 years and by me for the last year. He only ever ran regular and I've stuck with regular and it seems to run great. I haven't tried Premium in it for fear that it will run much better and I'll want to do it all the time. Ignorance is bliss, right?
I'll have my fleet down to 1 within a year and then I'll run Premium in it for the little I will drive it.
Old Jun 27, 2014 | 11:25 AM
HammerFit's Avatar
That's exactly why I was asking. I use mine for a DD. I'm burning thru 2 tanks per week. I know my crappy mileage is even more crappy now that I put the bigger tires on. I guess I'll stick with the pricey stuff, I don't want to upset the already sensitive girl.
Old Jun 27, 2014 | 11:36 AM
MonteroMan's Avatar
See my next post on this issue - the system hid this one for a while.
Last edited by MonteroMan; Jun 27, 2014 at 05:23 PM. Reason: See the following post - intially the first did did not show
Old Jun 27, 2014 | 11:43 AM
HammerFit's Avatar
Originally Posted by MonteroMan
In simple terms:
The Octane Rating is the clue here. Your elevation above sea level determines the octane rating you should use and nothing else.
At sea level a heavier load of air is ingested into the combustion chamber and a heavier load of fuel is also required. The weight of the fuel is a seperate issue than mere weaker or richer combustion mixture as determined by elevation).
Previously this was achived by a larger amount of tetra ethyl lead in the fuel. Nowadays other heavy metal additives are used. In Europe and South Africa fuel at sea level and up to about 2,000 ft elevation is 98 Octane, and at the higher elevations you have the choice of 87 and 93 Octane.
It is a wastage to use 93 octane above elevations of 7,000 ft.
To use lower octane than 91 in high compression ratio engines below 5,000 ft. creates a risk for too high combustion temperature and possibly pre-ignition and exhaust valve, and possibly piston head damage.
Im at 0 sea level! 1 block from water. High octane it is. Thanks for the info. That's the first time I've heard that info. Good stuff.
Old Jun 27, 2014 | 11:53 AM
MonteroMan's Avatar
Default It is the weight
In simple terms:
Octane Rating refers to the weight per volume of the fuel. At sea level fuel with a heavier mass per volume is required than at 10,000 ft. Previously tetra-ethyl lead was added to achieve this heavier combustible liquid but other heavy metals have replaced lead.
In Europe and South Africa 98 octane petrol is used from sea level to about 2,000 ft. elevation and above that 87 and 93 octane is available. It is a waste to use 93 octane petrol above 7,000 ft unless in a turbo-charged gasoline engine.
Similarly, to use 87 octane in a high compression ratio engine below 3,000 ft. causes distinct pre-ignition, and the same for 93 octane below about 2,000 ft. Pre-ignition is a spontaneous ignition before the spark plugs spark, is at very high combustion temperature and causes a severe kick-back to the rising piston, with increasing damage to the exhaust valves and piston top surface.
The old 3.80 litre V-8 of the Landrover was a low compression ratio engine.
joshjellel
Jun 3, 2015 10:52 AM
XCELLER8
Sep 10, 2014 09:48 PM
wesley64
Sep 11, 2008 08:02 AM
Chrisinhouston
Dec 19, 2007 10:20 PM
ferrelltodd
Jan 3, 2006 12:11 PM
