HomeLink
Old Feb 4, 2011 | 07:35 PM
joefresso's Avatar
Default HomeLink
All Electrical works in car, minus the factory HomeLink. There is no blinking light when buttons are pressed so I took it down and see that it's plugged in. Far as I can tell there is no fuse dedicated to this, but the manual doesn't mention it at all. Any thoughts?
Old Feb 4, 2011 | 08:07 PM
I dont know if it will light up if not programmed or not.
Just try to program it ans see what happens.
Old Feb 4, 2011 | 08:10 PM
joefresso's Avatar
well you have to hold it down until the light blinks and that never happens, so not possible to program
Old Feb 4, 2011 | 08:18 PM
I have no idea then, sorry.
Maybe the LED is burnt out?
Old Feb 4, 2011 | 08:39 PM
lordmorpheus's Avatar
Do your vanity mirrors light up when opened? Check fuse #15.
Old Feb 6, 2011 | 07:15 PM
jafir's Avatar
Have you checked for power? I have an extra one, but it's from an early 97 truck and won't work with rolling codes (has a red led). When I added this option to my 96, had to try the salvage yard twice to get the rolling code version (with the orange led). I'd part with it for shipping costs.
Old Feb 6, 2011 | 07:17 PM
joefresso's Avatar
I believe it's either not getting power or bad unit. Appreciate the offer but I need rolling codes as well.
Old Feb 6, 2011 | 07:28 PM
I never knew this, thank you.
Old Feb 6, 2011 | 08:13 PM
jafir's Avatar
Happy to share. The only reason I figured this out was that after I came back from the salvage yard with an armful of parts for $10 (I love you pull it places that have a rover or 2), I couldn't make the thing work. It would light up and everything... just would never program for my door. I googled all over and finally called homelink, and between the two it was confirmed. If I understand correctly, it works that way with all homelink, with a square LED, whether it's land rover or something else. Now if it's the triangle shaped LED, they should all be rolling compatible.
Old Feb 6, 2011 | 10:51 PM
Lee97Disco1's Avatar
Default Huh?
Ok, Im being nosey and learning at the same time here so,....
1. What is "Homelink" and where in my D1 do i find it?
2. What are "rolling codes" and why they are/are not needed?
