HomeLink
Old Feb 6, 2011 | 11:06 PM
UpChuck's Avatar
Homelink is a garage door opener integrated into your vehicle. It's the three little grey buttons in the center overhead panel, just above the rear view mirror.
Rolling codes may or may not be needed, based on whether or not your particular garage door opener requires it (it probably does). It basically changes the signal that the opener is looking for each time it receives one, based on some algorithm programmed into the opener and the remote. This is what keeps the crazy neighbor kids from driving down the road opening your garage for you. What they're saying is that the Homelink in the vehicle isn't programmed for this, and thus it won't work with garage doors that require it.
Old Feb 6, 2011 | 11:19 PM
Lee97Disco1's Avatar
Ah,....Thanx for the feedback UpChuck. I'm in an apt so a the present time i have no need for HomeLink but now I do know what it is! Thanx again for the knowledge.
Old Feb 7, 2011 | 06:30 PM
Homelink is nice if you have more than one remote operated thing, like a security gate and a garage door.
I have mine programmed for my garage as well as my mothers.
Old Feb 7, 2011 | 10:25 PM
UpChuck's Avatar
So Spike, you're saying that yours works with a rolling code opener, or no?
Old Feb 8, 2011 | 05:53 PM
I do not know.
I do not know how old my garage door opener or my mothers is.
Old Feb 8, 2011 | 09:18 PM
UpChuck's Avatar
Dang. I was hoping you knew something about programming it that I didn't. I would love to have that thing work on my garage door. Maybe I can rig up something else that it could activate. Like a neon "WELCOME HOME" sign or something.
Old Feb 9, 2011 | 09:41 AM
joefresso's Avatar
Checked mirrors and they light up and all fuses good. only things left are bad unit or not connected to power source. anyone know where the wires are run to to check entire connection?
Old Feb 9, 2011 | 09:54 AM
jafir's Avatar
There is a connection at the homelink unit. I think there is only power with key on. I'm not sure where it connects at the other end, my 96 didn't come with one so I wired it myself to a fusetap.
Old Sep 15, 2012 | 03:50 PM
MoonDisco's Avatar
3rd Gear
Default RE: Homelink
This is your built in auto garage door opener. either you have 3 buttons on the bottom of your mirror or below cargo light is a unit with 3 buttons. Program these to open up 3 different garages. also the rolling codes are used in older garage doors. you can manually change your code when ever you feel like it.
Hope that was helpful
Old Sep 19, 2012 | 04:37 PM
doorfixer's Avatar
4wd High
I stumbled across your post about homelink. It is relatively easy to program but is never explained well in owners manuals. It should be able to open most any remote controlled garage door that you have a working remote for. If you have a rolling code style door opener it may be a Genie Intellicode, Overhead door code-dodger, or Security plus lift master, chamberlain, or sears. It can usually handle any of these. I own a garage door company and am extra familiar with all of them. Any questions let me know.
