Hood Release is Stuck Close
Old Nov 1, 2025 | 08:20 PM
Toran's Avatar
Default Hood Release is Stuck Close
Hello Good People,
For the last few weeks I had been struggling to get my hood open. The hood release handle was slightly broken with a probably stretched cable. I had to remove the driver side headlight to access the release cable. After cutting it I removed the outer casing in order to pull on the wire to release the hood but it was a no go. I pulled so hard the remaining cable pulled out completely. Now I needed to drill into the metal security housing. I used a long screwdriver to push the lever to the right and yet the hood remained closed. After applying some lube to the area it was still a no go.
A picture of what I have to work with is included.
What should I be doing?
Thanks
Old Nov 1, 2025 | 09:02 PM
Mark G's Avatar
IDK, never had to do that. Doesn't look fun though.
Old Nov 2, 2025 | 10:41 PM
jimvw57's Avatar
A good reason to lube up the latches, especially the hood and rear door!! Might need to bang on the hood while the latch us being held open. unfortunately once the cable is broken they are extremely tough to get open. I think I ended up going through the grille but you still have to fight with that plate.
Old Nov 2, 2025 | 11:12 PM
Toran's Avatar
Painful...
I may have to take a dremel to more of the security plate to the left of the circled area.
Old Nov 4, 2025 | 12:49 PM
hrhoward's Avatar
A small, shaped explosive charge might do the trick.
Old Nov 4, 2025 | 05:49 PM
Toran's Avatar
Got the hood open.
Had to dremel out the Hood Latch STC925. Got a new one coming. Still haven't found a source for the metal security bracket AWR4767.
I found the D2 OEM Hood cable I got from Paul Grant years ago. Best be putting that on when the other parts arrive. I will remember to lube the hell out of this gear from here on!.
Time to look into that Saudi Grill now.
Old Nov 5, 2025 | 05:03 AM
jimvw57's Avatar
Good to hear! I did the rounds of lubricating door latches and hood latches after you posted this. I should replace the cable on my D1 as the handle broke, but I can still use it using the claw side of a hammer (under the seat)
Old Nov 5, 2025 | 08:26 AM
Toran's Avatar
This is the plan for the D1...
Old Nov 10, 2025 | 11:54 PM
Harvlr's Avatar
I don't know if it's the same as the D2. On mine I removed the security bracket in case I ever need to do what you just did. (I'm thinking you should leave the security bracket out, I don't think anyone is trying to steal engine parts from these).
Old Nov 12, 2025 | 10:06 AM
Toran's Avatar
Hey Harvlr,
I think that is the route I'll be following.
Thanks
qld2002
Defender
Oct 13, 2024 07:21 AM
steveo2000
Sep 8, 2015 08:00 AM
bikingteacher
Jun 19, 2015 04:23 PM
Cookse7
Jan 17, 2015 10:38 PM
kram2179
May 16, 2005 12:34 AM
