Horrific Vibration under load-can't do over 35...
Old Aug 6, 2013 | 03:15 PM
formel3's Avatar
took out front driveshaft, locked CDL and vibration is totally 100% gone. Guess that means it's new driveshaft time!
Old Aug 6, 2013 | 03:29 PM
fishEH's Avatar
Glad you got it diagnosed. I'd say with 3"of lift you'd be safe to go DC. Check your angles just to be sure, though. The Woods is totally plug n play. Make sure you grease the ujoints and DC before installing. ;-) When you order you'll probably be asked for a measurement from pinion flange to TC flange. You may try Will Tillery, he had the best pricing when I bought mine.
Old Aug 6, 2013 | 10:33 PM
formel3's Avatar
ordered the Woods DC shaft. Good price, and they said they would have it in the mail tomorrow. Is there a grease for the axles that people prefer?
Old Aug 7, 2013 | 04:57 AM
antichrist's Avatar
90, 85w90 or 85w140 gear oil in the diff.
One shot or remove the axle housing seal and run gear oil in the swivels.
Good disc brake rated grease (I use Castrol Pyroplex Blue) in the hubs, or remove the stub axle inner seal and run gear oil if you're running gear oil in your swivels.
Old Aug 7, 2013 | 03:33 PM
formel3's Avatar
thanks! I am still trying to figure out what all points need greased on it regularly-I already run 85/140 castrol in the T-case and diffs.
robertmirwin
Oct 8, 2013 12:56 PM
Disco203
Aug 19, 2013 09:48 AM
teddyz
Aug 2, 2013 11:56 AM
SolbergFanBoi
Mar 5, 2012 07:05 PM
kruth
Mar 5, 2009 03:41 PM
