Hot start problem, at the end of my rope
Thanks so much for the information!!
Yes, I am still getting the P0340 code, but think it might not be related to the hot start problem....not sure, suppose I'll find out when I get the pump fixed.
Also, I think I confirmed that my fuel pump is indeed going out, as if the 10-15 lbs of pressure it registered on the gauge wasn't enough! Today I drove it quite a bit and let the gas tank get down to about 1/4 of a tank...it REALLY struggled to run and when I pressed on the gas it just didn't want to go at all....filled up the tank and it was much better...could the weight of the fuel be "helping" out the bad fuel pump?
The PSI the fuel pump is putting out seems very low to me. It should be around 20-30PSI, but I don't think a fuel pump would be triggering the P0340 fault. The wire leading down to the CPS is known to age, crack, and short out causing all sorts of issues from not starting, not revving past say 2,500-3,000RPM, or like you it has a mind of it's own when starting. I recently saved/repaired two D1's both which would not run a 98 and a 99. Previous owners had given up on them and put em out to pasture. My friend bought em, and with a little trouble shooting it was the wire going to the CPS on the 99 D1, and on the 98 D1 it was simply not plugged in all the way!
Since you have a 98 with AEL it is certainly cheaper to just replace the fuel pump itself, and the sock attached to it. The entire assembly for a D1 equipped with AEL is not cheap. It's not a hard job and you can find fuel pumps online for as little as 15-30.00 with a new hose, clamps, connector, fuel pump, and sock. That should get your PSI back up into the normal range. If you still have P0340 check the wiring on both the Crank and Cam sensors for broken insulation. If either one of those sensors are acting up P0340 will get triggered.
WaltNYC (07-31-2020)
UPDATE:
Thank you for sharing that video, exactly what I needed.
I swapped the fuel pump out last night and took it for a quick test drive...so much more power, especially when climbing a hill or kicking it down on the interstate. I suppose my old pump must have been barely working.
I drove it to work today and will toodle around a bit before going home, hoping to find out if this fixes my hot start problem. Fingers crossed, I'll report back. Thanks everyone.
The following 2 users liked this post by jekylczar:
Banzai Jimmy (08-04-2020),
WaltNYC (08-04-2020)
jekylczar
07-21-2020 11:57 AM
