How do I bleed my coolant system
Old Nov 18, 2011 | 10:58 AM
Top of radiator - battery side - remove fitting when cold and nose elevated.
Old Nov 18, 2011 | 10:59 AM
Discolife's Avatar
Default How do I bleed my coolant system
I imagine its in the RAVE but dog gonit I can figure out how to use it well.
I need to burp my coolant system after new motor and tranny instal we get the sloshing sound.
Thanks fellas and ladies
Old Nov 18, 2011 | 12:11 PM
Danny Lee 97 Disco's Avatar
Yesterday in the partss store I looked at a Peak 5 dollar kit that you basically cut the heater hose and install a flushing tee. When you want to backflush, you connect a garden hose to an adapter in the kit to the flushing tee.
The flushing tee is left installed in the hose. Has anyone tried these?
Old Nov 18, 2011 | 12:19 PM
hh65flyer's Avatar
Those kits have been around forever and work well. The only downside IMO is adding another weak point in your cooling system...that is more hose-clamps and a plastic piece that can break.
Old Nov 18, 2011 | 01:14 PM
Discolife's Avatar
How elevated? LOL
Old Nov 18, 2011 | 08:56 PM
Bleeding the system is easy, start with a stone cold engine.
Remove fill plug on radiator and overflow tank.
Top off system, start engine turn both sides to full hot, roll down drivers window and put HVAC control to "dash" or "vent"
HVAC fan on low.
Let engine idle, t-stat will open and coolant will start to flow out of radiator fill plug.
Once only coolant comes out and not air bubbles put that cap back.
Leave engine running the whole time.
Once a steady stream of steam comes out of overflow tank put the cap back.
The whole time this is going on keep a eye on the temp gauge and stick your hand infront of the vent to make sure you are getting hot air.
Once done you can shut it off, do not shut it off with the system open.
Drive for a day or 2 and check and top off after it has sat all night.
Whole thing takes 30 min or so.
Old Nov 18, 2011 | 09:39 PM
Discolife's Avatar
thanks
Old Nov 21, 2011 | 06:11 AM
DiscoBlanco's Avatar
HVAC fan on low.
Great Writeup! This should be in tech.
However, I would make one change..... Top off your fuel before you start. I had to run that beast for over an hour to get all those bubbles out. Agitating the top hose helped a bit (dont squeeze it, just tap it or wiggle it.)
Old Nov 21, 2011 | 06:48 AM
If you have ramps available, put one ramp on battery side to raise that corner.
Old Nov 21, 2011 | 07:57 PM
I believe it is in the tech section all ready.
