how do I fix that that rear wheel well A/C line on the SE7?
Old Aug 29, 2012 | 10:30 PM
VikingDiesel's Avatar
Default how do I fix that that rear wheel well A/C line on the SE7?
My A/C works good for 5min and then it leaks out of that A/C line on the left rear wheel well thats intended for the rear 3rd row occupants. I would like to just get rid of that line entirely and plug it with a bolt or something, any ideas? I can image its very expensive at the dealer, also, how the heck do you loosen that big nut, impossible to get off?
Old Aug 30, 2012 | 06:24 AM
An indy AC shop should be able to handle that for you. But it may be more expensive to modify lines than simply find the leak and repair. As an example, there are O-rings in the fittings of the rear unit. Here's a page from the RAVE shop manual. If going indy shop, would suggest you print out the AC section from RAVE and take it with you.
File Type: pdf
Rover_Hokie
Apr 27, 2013 10:07 AM
1badcj8
Apr 10, 2013 10:52 AM
JerrodSteph
Jun 12, 2011 06:04 PM
Landifan
Jan 4, 2011 10:52 AM
dgelfuso
Dec 24, 2010 02:33 PM
