How Do I Wiring Fog Light To Work Regardless Of LAMPS
Old Sep 10, 2010 | 08:33 PM
Spencerfitch's Avatar
Default How Do I Wiring Fog Light To Work Regardless Of LAMPS
I just installed some hella 700's on my front bumper. I wired them up to the fog light wires, since I ditched my fogs a while back anyway.
Well I find that it only works with low beams on. I want it to work no matter what.
I know I know, wire it up to a constant 12v, but I dont know where to start, or what wire to do that with?
Old Sep 10, 2010 | 08:38 PM
tornado_735's Avatar
You're going to have to run a separate switch. Run a wire from the lights to the cabin. Run a fuse protected wire from the positive battery terminal to the cabin. Connect those to a switch. Voila.
Alternatively, you could figure out how to take the relay that disengages the fogs out of the circuit. You're going to have to find a wiring schematic though.
Old Sep 10, 2010 | 08:41 PM
dont you hate when you ruin a title like that?
anyways I was hoping you WOULDN'T say that.
Old Sep 10, 2010 | 08:43 PM
I added an edit to my first post.
Old Sep 10, 2010 | 08:56 PM
okdiscoguy's Avatar
Kids, do I need to draw a schematic for you?
Old Sep 10, 2010 | 09:10 PM
okdiscoguy's Avatar
It appears, through Rave, that the fog switch gets power from fuse 11, which is only on when the regular lights are on. I would find any switched power source at the fuse box and tap into that. Cut the Blue/black wire feeding the switch. Cap the side coming in and tie the switched source to the wire going to the switch. Pretty sure there is a spade terminal on the fuse box with switched 12V. Or you can find a line for the parking lights...
Then you have spots at all times...It can be done...
Attached Thumbnails How Do I Wiring Fog Light To Work Regardless Of LAMPS-fog1.jpg
Old Sep 10, 2010 | 09:19 PM
You can still use the factory switch if you want.
Urban Panzer did this for his roof lights.
Same thing that you want to do, lights is lights.
http://www.discovery2.co.uk/
Old Sep 10, 2010 | 09:24 PM
okdiscoguy's Avatar
UP ran new wires for his lights. My way lets you keep the factory wiring and relay and just switch them on any time you want. I can turn mine on with the parking lights on. My others come on with my brights.
Old Sep 10, 2010 | 09:32 PM
Thank You. !!!
rambo
Oct 17, 2013 10:13 PM
zigzag3141
May 13, 2013 09:12 PM
longjon76
Oct 3, 2011 06:31 PM
Rovin4life
Off Topic
Aug 20, 2011 06:48 PM
A12LR3
Nov 12, 2006 11:20 AM
